Old 11-25-2014, 04:22 AM
BADSN8K's Avatar
Cobra Make, Engine: BD 1445 Coyote TKO 600 3.91
Default NEED MSD HELP Losing power and replacing parts
Hello all!
I have a 67 EM with a 406 Ligenfelter
Digital 6AL
8416 roto and cap
8225 coil
Finding that I have to replace roto and cap every 1000-3000 miles
Losing power while driving.
NOTE pic attached is cap before I switched to MSD.
Any suggestions or is this normal????? SMH!!!
hope someone can offer help!!!
Old 11-25-2014, 05:22 AM
Dwight's Avatar
Smile
this is normal for MSD
I run a stock Ford cap with no problems.
but my buddies with MSD have that problem. Called MSD and they know about it but have done nothing to correct the problem.
I think it's the material they use in the cap combined with the high voltage.
IMHO
Dwight
Old 11-25-2014, 05:38 AM
joyridin''s Avatar
The part number you have shows a GM HEI cap and rotor. Try a Petronix cap and rotor. I just put them on my car and they seem to be better quality than the MSD versions.
Old 11-25-2014, 07:45 AM
DonC's Avatar
Coastal:
Your problem is very basic. You've got the engine in backwards. Turn it around and that should cure the problem. (Sometimes I just can't help myself) );-)
DonC
On the MSD gear, the rotor tang often doesn't make full contact with the carbon button on the inside of the cap. Put in a new rotor and cap, and bend the tang on the rotor up to ensure it makes good contact. This is a known issue and could very well solve your problem.
They will replace under warranty for this, btw.
Old 11-25-2014, 11:54 AM
Bernica's Avatar
Senior CC Premier Member
And get an extra rotor and cap to keep in the trunk!
