Like Tree1Likes
  • 1 Post By ninexrep
Old 10-24-2015, 10:18 AM
505stang's Avatar
Cobra Make, Engine: B&B 351C
Default electric choke
I need to hook up my electric choke but am a little confused as where to hook it up, car has a single wire alternator, g.m. style. Normally on a ford external regulator i think it should go to the stator, or s on the regulator, beings that it is a single wire where would i go? Any help would be great.
Old 10-24-2015, 11:43 AM
Grubby's Avatar
Cobra Make, Engine: ERA 838
Hook it to any wire that is 12v when the key is on.
Old 10-24-2015, 02:53 PM
DanEC's Avatar
On the chance that you are another points ignition dinosaur like me, I hooked mine up to the ignition switch side of the ballast resistor. Since it had spade connectors I made up a little harness piece with female connector to the resistor and two male connections - one to the harness back to the switch and the other to the choke lead. That way it receives 12 volts. I would probably not try to wire it directly to the alternator.
ERA 782 Running
Old 10-24-2015, 07:46 PM
Cobra Make, Engine: johnex
If I remember they were only 7 volts. So u can go key on pwr with a old dodge resistor. 12 volts made them open to quick.
Old 10-25-2015, 03:51 AM
Tom Cimino's Avatar
Cobra Make, Engine: Everett-Morrison 427SC 302 smallblock. 431 stroker in the works, tremec 3550
Here's another question that goes with this subject. Do you put a fuse or breaker in line with the power feed to the choke?
Old 10-25-2015, 05:21 AM
DanEC's Avatar
I installed a Holley choke kit on my car and the instructions did not say anything about separately fusing the lead to the choke - just wire in to a 12V source switched by the ignition switch.
https://www.holley.com/products/fuel...s/parts/45-223
ERA 782 Running
Old 10-25-2015, 05:46 AM
Cobra Make, Engine: BDR Build #1054 351W stroked to 427
Do yourself a favor and make it a hand choke rather than electric. On mine the electric choke opened way to fast resulting in being hard to start on occasions. Installing a manual choke cleared up the problem.
Luke427 likes this.
Old 10-25-2015, 11:00 AM
Tim7139's Avatar
Cobra Make, Engine: Superformance #2660, FE-406
It would appear some engines, for whatever reason, simply do not respond as hoped from cold with an electric choke.
My engine runs well and I played around for some time with the electric choke and playing with a wide variety of cold start settings.
In the end, I resorted to what so many drag race guys do, I just disabled it and use good old fashioned pedal modulation for the first 3-4 minutes from cold.
Works quite well and it does'nt get any easier, frankly.
The older I get, the faster I was.
Old 10-28-2015, 08:47 AM
505stang's Avatar
Thanks for the help on where to wire the choke, it is wired now and starts a hell of a lot better now that it works and it's getting colder out thanks again!
Old 07-12-2016, 05:03 PM
Luke427's Avatar
Cobra Make, Engine: Unique Motorcars, Ford 427 FE Side Oiler
My 427 with Holley electric choke is in that case. Some (fairly rare) times I end-up opening the hood, remove the airfilter bolt, take it of, flip the choke manually then it would immediately start.
I'm replacing the intake with a dual carb setup and will have manual choke
Old 07-13-2016, 12:52 PM
Cobra Make, Engine: ERA 427 S/C, Ford 427 Side-oiler 2x4 bbl
The/An advantage to using the alternator as a power source is, the bi-metalic spring doesn't heat up until the car is RUNNING as opposed to simply with the KEY ON (Engine Off).
A direct connection could result in the choke opening with the car sitting, Key On/Engine Off (KOEO).
Bottom line is, it's a personal choice. I personally would probably use the ignition as a power source but I would also fuse it between the resistor (or coil Pos (+) if I used it) and the choke element.
Better safe than sorry,
Phill Pollard
Old 07-13-2016, 02:00 PM
When I changed over to a non-choke carb, I traced the connecting wire back to the ignition switch. No resistor or fuse. Key on, choke operable.
Old 07-14-2016, 07:42 AM
davids2toys's Avatar
No choke on a Cobra for me, but if I were to install one, it would be a manual version for sure, Simple, works perfect and you are in total control
