Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > JBL-- JBL Larry G.
Old 10-02-2012, 03:24 AM
Default Did you have weight in drivers seat?
vector1 Did you have your weight in the drivers seat? If yes the numbers are good. It's a pain but having the thrust angle at "0" is also important for having a car lay the power down and go straight. The number is low and you have no weight in car to match yours. If you do another check with you in the car you will find different numbers. There the corner weights setup first? This will also change the numbers if not done. I have been there though all this. It's a pain but at the end the car handles so much better. Rick L.
Display Modes
