Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > JBL-- JBL Larry G.
Old 10-10-2003, 01:01 AM
Default phenolic spacers
What is the best material to use as phenolic spacers on Webers IDA's intake manifold?
Bernie
Bernie 289 FIA
Old 10-22-2003, 03:13 PM
Send a message via AIM to David Hadley
Default Re: phenolic spacers
Bernie
Bernie
Carb spacers as a heat barrier (I assume) can be made of several different materials. Phenolic (garolite) Grade G10 is good to about 284 degrees. Grade G11 is 338 Degrees. Grade G-30 is a glass fabric with a resin binder that can stand 464 Degrees but is only available in 1/4 thick. I have used a Hardwood or Plywood to make spacers also. Birch or Oak works well.
Good Luck
JBL Dave
