Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Keith Craft Racing
Old 08-13-2010, 06:30 PM
Voyager's Avatar
Cobra Make, Engine: SPF #2920 w/ Keith Craft 408
Default float bowl level
Took my new Cobra for a spin today. Need to address a couple things. The car is occasionally stalling when I come to a stop. Idle is set at 950 rpm. Engine is a Keith Craft 408 street crate motor. Carb is a Quick Fuel Hotrod Series Carburetor, HR 750. Noticed the fuel level in the float bowl windows are both at the top. Should they be at ½?
Old 08-13-2010, 08:38 PM
FWB's Avatar
FWB FWB is offline
they should be at the bottom. i assume you have the clear sight windows. normally there are screws in the holes correct float level should be when fuel barely drips out of the hole when running.
so with the clear sight windows you should not see an actual fuel level. if you do the level is too high.
Fred B
Old 08-13-2010, 08:53 PM
Default I agree
my barry grant carb did the same thing, I called the tech dept at barry grant, they told me to have front bowl at a quarter, of the sight glass and the rear bowl at the bottom of the sight glass, and guess what no more stalling.
Old 08-13-2010, 10:02 PM
Both suggestions should help. Make sure that your fuel pressure is not more than about 7 lbs. To much fuel pressure can cause the needle and seat to leak. Set the float levels like mentioned above and it should help. I feel that when you come to a stop you are getting a little pushed out the air vent possibly in the back and flooding you out. Do you notice a little black smoke when you restart the car?
Good luck, Keith
Keith C
Old 08-14-2010, 12:53 PM
Voyager's Avatar
I’ll lower the fuel levels. Stupid question time - to lower the fuel level in the bowl, do I lower or raise the float? I experimented with raising and lowering the float in the rear bowl and could not see the fuel level consistently move up or down in the sight glass.
Yes - black smoke when I restart the car.
I’ll verify the fuel pressure with the engine installer.
I’m loving the motor…
Old 08-14-2010, 01:10 PM
Calbullet's Avatar
Cobra Make, Engine: Superformance 460 SVO
Voyager, to lower the fuel level, you need to lower the float. also you will need to rev the engine a couple of times to use the excess fuel in the secondaries. this will let the rear bowls find there levels.
Old 08-14-2010, 07:31 PM
FWB's Avatar
FWB FWB is offline
um, i think you have that backwards....if the float goes lower it opens the needle.
anyway turn the nut clockwise to lower the fuel level.
Fred B
Old 08-14-2010, 08:16 PM
Default I hope you have a fire extinguisher
have fire protection when your doing your carb stuff dude .
Old 08-14-2010, 08:23 PM
If you have a electric fuel pump, key the ignition turn pump on and do it that way cold.Also bleed your carb down low then build it up much easier.with the engine turned off.
Old 08-14-2010, 10:17 PM
Calbullet's Avatar
FWB when you turn the adjustment screw clockwise, you are lowering the needle/seat lower in the fuel bowl and lowering the float also. with the float lower, less fuel will be needed to push the float up and close the needle/seat.
Old 01-03-2013, 06:44 PM
mattpatt's Avatar
Cobra Make, Engine: Superformance SP3033, KC SBF 427
Just found this thread. According to Quick-Fuel the fuel level sight windows should show the fuel level half way up the window. I'm having a stumble problem on hard braking (KC all aluminum 427 (351W) with QF 780 carb).
I'm confused (info in this thread and the QF site info not the same).
Can anyone clear this up?
Many thanks!
Old 01-03-2013, 11:17 PM
WardL's Avatar
I get an engine flutter when taking a hard turn. My levels were in the middle of the plastic float windows. I think I need to lower them. The plastic float windows are intended for temporary use only. I had the plastic windows in my carb when I purchased it used and when fooling with the floats found they had dissolved to the point where they were about ready to leak and quite dangerous. Only use the clear plastic inserts for adjustment. Once the floats are set where you want them, put in the brass inserts for normal use.
Old 01-08-2013, 10:18 AM
Voyager's Avatar
Wow – back from the dead…
I lowered the fuel level to ½ or so. 2 years and 3500 miles later, it still threatens to die if I jam on the brakes real hard (near lockup). I blip the throttle in-between downshifts to keep the revs up. Since I’m not racing, it’s not really that big of a deal.
Was not aware the site windows in Quick Fuel carbs were for temporary use only?
