Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Keith Craft Racing
Old 05-13-2005, 10:03 PM
Cobra Make, Engine: ERA 427 w/496 Side Oiler, roller, dual quads
Default No Dipstick hole in Genesis Block
I just finished the assembly of my Genesis short block. I just noticed there is no hole for the dipstick. Now what do I do?
THANKS,
Dan
Old 05-13-2005, 10:40 PM
Club Cobra Member
Original Shelby Owner
Cobra Make, Engine: Purchased CSX3225 in 1968 for $4,995. Original 428 car but changed to 427 MR about 20 years ago.
Aviad 9 Qt Cobra Oil Pan has an opening for a dipstick on the right side of the engine. You can buy the dipstick setup from the supplier of the pan. This is the pan that was used on SC Cobras. The pan also has openings for the oil temperature gauge and the drain from a slop tank.
Old 05-14-2005, 04:35 AM
Hotfingrs's Avatar
Cobra Make, Engine: EM cobra, 450 inch sbc running a best ET of 9.14..so far..ALL MOTOR...approx 800 horse.............ERA with 482 FE..All Aluminum Engine
Send a message via Yahoo to Hotfingrs
Pretty easy to make your own...I did. Use brake line, 5/16 or 3/8 I forget which one fits the dip stick just right. then get the flare fitting for the size hole in the oil pan. Run the line anywhere you want up the side of the engine. Put the dip stick in, and put the right amount of oil in. Then just look at the dip stick and mark the oil level, so you know where full is. After brake is bent to where you want it, and you cut it to length, the dip stick fits perfectly.
Jack
XSSIVE .....
Old 05-14-2005, 06:27 AM
CC Member / Sponsor
On an Aviad / Armando's pan use a big block Chevy dip stick. Bolt it to the top passanger side water pump bolt. Trim the bottom to fit, clamp it on with fuel line, and the fill mark is almost perfect.
Cubic Performance
HiTech Legends
https:HiTechLegends.com
Evolve Lubricants
https://evolvelube.com/
Old 05-14-2005, 04:08 PM
All great ideas, gentlemen...but I've got a Canton pan. It has an opening for an oil temp sender, and I plan on using it for that. Do any Genesis blocks have the dipstick hole?
The oil pump shaft hole wasn't drilled completely through nor had a flat on the bottom side so the shaft wouldn't fit until I fixed that. I expected them to have these bugs straightened out by now...
Old 05-14-2005, 07:19 PM
2KWIK4U's Avatar
Cobra Make, Engine: Lonestar LS427, Keith Craft 496 Genesis, 649 hp, 668 ft-lb, TKO-600, Dynatek Stack EFI
Carnut
My Genesis block has a dipstick hole directly to the rear of the oil filter adapter. I believe that is where the original blocks had them. I did however us the provision in the Armondo pan since the windage tray interfered with the stock location.
Brad W.
A good friend will come and bail you out of jail...but, a true friend will be sitting next to you saying, "Damn...that was fun!"
Old 05-14-2005, 09:07 PM
2KWIK4U, I had this pan and the Canton windage tray on my original 427, and remember interference as you described. I've got a rivet-on dipstick tube from an old Ford pan...perhaps Ill look into using it.
Thanks for all your replies,
Dan
