Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Keith Craft Racing
Old 02-21-2006, 02:26 PM
Default 302 Block RPM Limits
Keith,
How much stronger are the early 302 and Mexican 302 blocks compared to the thinwall 5.0 block? What would you consider to be a safe RPM level (Or piston speed) for the different blocks with a 3.00" stroke, normally aspirated?
Thanks for your help,
Kevin
Old 02-21-2006, 09:27 PM
The safe limits for rpm on these blocks has a lot to do with how the crank is balanced, the weight of the rotating assembly and how the engine will be used. The early blocks and the mexican blocks are stronger than the later blocks because they have more metal in them. The main web area is stronger along with the deck being thicker. We have ran the early blocks in some of our Super Stock NHRA drag cars as high as 8400rpms but these engines only make about 450HP and have light pistons and rods. I fel the late model block is good for about 500HP safely over the long haul and the early blocks about 550HP. We have put aftermarket caps on the early blocks and made 600 to 626HP and turned them 8500rpms for a season of circle track racing. The shorter strokes like the 3.00 are easier on the blocks than the stroker cranks. Hope this helped a little. Thanks, Keith
Keith C
Old 02-22-2006, 05:22 AM
Keith,
Thanks very much for the info. It's always nice to hear from a source who unquestionably knows what he is talking about.
Do you think the Mexican block is sufficiently better than an early 302 to be worth the trouble of finding one for an engine that will make 450 to 500 HP NA @7,000 to 7,500 RPM? The engine would be Street / Track, so longevity is one of the things I am looking for. (Forged Crank, Rods & Pistons, 28oz imbalance).
Thanks,
Kevin
Old 02-24-2006, 03:45 PM
When you put aftermarket caps on, do you also use a girdle? And do you replace all 5 caps?
When is replacing the caps necessary?
Thanks,
David
