Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Keith Craft Racing
Old 12-02-2006, 07:26 PM
Banned
Default Typical Power from 527 Aluminum FE?
What is the typical power from 527 (4.375 bore and stroke) Aluminum FE from Keith Craft?
I'm looking for answers from the owners of these engines.
Old 12-02-2006, 07:51 PM
jwoodard's Avatar
Thumbs up
An easy 700 FWHP.
Jim Woodard
Old 12-03-2006, 12:38 AM
brettco's Avatar
Cobra Make, Engine: Hi tech 427 SC
More than you could ever use-by quite a bit.
Old 12-03-2006, 03:52 AM
427SnakeSC's Avatar
Cobra Make, Engine: Shelby CSX 4995, Keith Craft built 427 SO
Send a message via MSN to 427SnakeSC Send a message via Yahoo to 427SnakeSC
Keith has estimated that my 427 (482) cast will put out in the area of 630 hp. I am sure that an all aluminum 527 will be putting out at least 700 hp, and as brettco said, "More than you could ever use!" I am trying to get Keith to build mine in the area of 500 - 550. Really, in a car that weighs 2,500 lbs, do you honestly think you will be able to use 700+ hp? IMHO
"The 427 Cobra is easily the highest performance car ever sold for street use. A decent 427 - not the worst, not the best, will go from zero to 100 mph and back down again to zero in less than 14 seconds. All thing considered, you can put together a pretty good argument that the 427 Cobra is the ultimate performance car, judged on any basis you want to name." Taken from; Corvette, The Sensuous American
Old 12-03-2006, 06:52 AM
289 FIA Fan
rsimoes,
Why don't you want Keith's input - he builds and dynos them?
thorin
Old 12-03-2006, 09:51 AM
Banned
Originally Posted by Thorin
rsimoes,
thorin
Perhaps my request came out wrong. I was not trying to avoid hearing from Keith. I was trying to avoid hearing people's guesses, that's all. I figured the owners would have dyno data. .
Oh yeah, I'm not looking for max HP, I'm just curious as to where the 527's end up in power. . .
Old 12-03-2006, 02:17 PM
What are you doing now Rob?
Didn't you just sell a 527ci FE and a Superformance Cobra?
You're worse than a woman.
Old 12-03-2006, 02:38 PM
Banned
I can tell you in private what's going on.
Old 12-03-2006, 05:12 PM
Shoot me an email.....
brentlykins@hotmail.com
Old 12-03-2006, 05:45 PM
Banned
I will this week. Long story.
Old 12-03-2006, 06:16 PM
Hey Ron, would you mind copying me? I would love to know "the rest of the story"! You have my e-mail address.
Rodger
Old 12-04-2006, 06:02 AM
Banned
By the way, yes I did, but it was NOT a Keith Craft motor.
Old 12-04-2006, 10:12 AM
Cobra Make, Engine: SPF, Ford
FWIW, KCR built a 514 motor for me that made 765HP @ 7000, 700lbs @4500. It's an iron block w/ full mechanical roller and TWM stack indcution on top. The design goal was streetable power on pump gas so the cam is mild (112deg lobe centers, 258deg duration @ .050, .738" lift). Runs like a Honda... until you mash the loud peddle. A more agressive cam I'll bet would make 800+HP.
Old 12-04-2006, 10:41 AM
Cobra Make, Engine: owned Kirkham for 11 years
rismoes,
My 511 Shelby with hyd roller is 664 hp at 6000 rpm.
Feels good
Maurice
Ps, Does not run like a Honda at anytime
Old 12-04-2006, 11:13 AM
Banned
Are these high HP motors typically hydraulic lifters or solid? Is the only draw back from solid lifters the need to adjust valves more often and noise or is there more?
Old 12-04-2006, 11:19 AM
undy's Avatar
I think (most) anything above 700 hp will require (normally) a solid roller. There are many large cubic inch FEs running out there in the 600+ Hp range (such as mine) that's running hydraulic rollers.
Dave
Too many toys?? never!
Old 12-04-2006, 12:40 PM
Yes, solid lifter need regular adjustment, about every 1K miles. In addition, they need to be replace every 15K miles or so. Cost is $350 or so in parts.
The main advantage of solid lifter is that you can have steeper cam lobes yielding more HP and turn higher RPM's. I can tell you first hand that a 7800RPM redline on a 9L motor is pretty thrilling.
Starts and idles like a Honda but runs like a scalded dog when prodded...
