Old 12-20-2009, 01:12 PM
Cobra Make, Engine: Kirkham 482 ci alum block
Default Hood scoop question for a Kirkham
Hello everybody,
I am in the process of recutting the opening for the hood scoop. My question is when you cut your openings did you follow the hood scoop contour all the way to the rear?
When I got the car it was cut to the shape of the oval air cleaner. The previous owner did not finish the edges of the cut to my quality standards.
Question for David @ Kirkham, what size aluminum rivets should I used to reattach the hood scoop?
Old 12-20-2009, 02:35 PM
767Jockey's Avatar
David,
The orginals had the oval opening in the hood, they did not have a hole the size of the scoop. Look in my gallery, if memory serves me correctly I have a picture in there of the underside of my hood with the proper shape, size and placement of the actual opening in the hood below the scoop. ERA also has a great diagram in their manual and on their website. I hope this helps.
Old 12-20-2009, 02:58 PM
HI Cobra's Avatar
Mine has the oval cut out too. I am guessing they didn't cut out any more
than necessary to try to keep metal there for structural integrity.
Flip
Old 12-20-2009, 04:00 PM
Here are some pictures.
Old 12-20-2009, 04:43 PM
KarlCSX2498's Avatar
Cobra Make, Engine: CSX2498 has been in our family garage since '68....Scratch built aluminum bodied 427SC Cobra, 427FE, CSX3000 chassis specs, 95% finished, only needs paint.
What type of edge is on the opening on the hood? Does it have a hem? Or a return of any kind? thanks, karl
Old 12-20-2009, 05:32 PM
HI Cobra's Avatar
I could be wrong here but that oval in the picture sure looks like what I have on mine.
Flip
Old 12-20-2009, 08:01 PM
Default Hood Scoop
The original 427's had an oval opening with a downstanding flange. The opening was centered on the engine. The hood scoop was centered on the hood.
Old 12-21-2009, 06:20 AM
LMH's Avatar
LMH LMH is offline
As far as I know, there was a small flange that stuck down around the opening.
Old 12-21-2009, 06:46 AM
computerworks's Avatar
Original Comp and S/C had the cutout pounded down and around to present a flange-type edge on the underside of the hood
Old 12-21-2009, 09:17 AM
FatBoy's Avatar
I stand corrected.
Old 12-21-2009, 09:48 AM
franklin's Avatar
Cobra Make, Engine: Polished KMP #488 / 427SC, 427 SO/482 by KC
Here is a picture of mine.
Underside of the hood is brushed and the underside of the hood scoop is polished.
The rivets are usually 1/8". I used button head allen head small bolts so the holes have to be a little larger than 1/8". Either one works.
Old 12-21-2009, 11:57 AM
Jamo's Avatar
Super Moderator
David...it wasn't cut that way for an oval air cleaner (street cars)...more to sort of match up with the single carb/turkey pan used on the Comp and S/C cars.
Jamo
Old 12-21-2009, 05:08 PM
Thanks for all input. I really appreciated the pictures, they say what many words can't.
Jamo,
I am sure that Kirkham did not cut the opening, it wasn't even close to there quality standards.
I am doing many special touches to the car, I will post pic's when done.
Old 12-21-2009, 05:13 PM
Jamo's Avatar
Super Moderator
David...I was commenting more on why the oval shape, regardless of who cut it. You referred to the oval air cleaner...
Jamo
