December 2025
Old 01-23-2010, 10:19 AM
Cobra Make, Engine: Kirkham 592
Default What fuel log are you guys using with the turkey pan?
I had a nice braided one that doesn't fit
thanks
chris
Old 01-23-2010, 11:19 AM
MFE III's Avatar
Cobra Make, Engine: Hurricane Motorsports, 427w
I had a local shop fab one for me. It's 3/8" hard line.
Matt
Hurricane Motorsports #1053; 427w
Old 01-23-2010, 02:34 PM
Bernica's Avatar
Senior CC Premier Member
This is the setup I have. Flex and AN's to the carb. Take-off on back goes to the fuel pressure, which is a fluid isolator to keep fuel out of the cockpit.
Old 01-23-2010, 02:53 PM
Those look very nice. I was looking for an off the shelf item. Is there an off the shelf line that will work with Kirkham's turkey pan?
Old 01-23-2010, 03:35 PM
pgermond's Avatar
I picked one up at the local Kragen that fit mine.
Phil
http://www.uniquecobra.com/
Old 01-23-2010, 07:08 PM
damdfw's Avatar
Cobra Make, Engine: CSX 4973
I have an extra one (came with my runner kit) that is for use with a turkey pan. I did not use it as I have dual quads. If your interested let me know. It looks like this one.
http://www.clubcobra.com/photopost/s...7/ppuser/27494
David
Old 01-23-2010, 10:15 PM
I'm interested but are you sure it will fit a Kirkham turkey pan?
Chris
Old 01-24-2010, 07:47 AM
FatBoy's Avatar
Cobra Make, Engine: Kirkham #523, 427 S/O
I've used a standard off the shelf Holley item. It also has a connection point for the Kirkham fuel pressure sender.
Old 01-24-2010, 07:57 AM
Kirkham makes and sells some extensions that work great with the turkey pan.
Call Dave on Monday and ask about the setup. 801-377-8224
Old 01-24-2010, 07:58 AM
damdfw's Avatar
I'm not sure. Does the Kirkham pan have different dimensions than other available pans? I have purchased some other components from Kirkham for my CSX and they work fine. Would it help if I took some measurements?
Chris
David
Old 01-24-2010, 08:46 AM
I'll call Dave on monday to ask about the extensions
Old 01-25-2010, 02:41 PM
damdfw's Avatar
Chris,
Let me know what you find out. Another cc member is now interested in my fuel log.
David
Old 01-27-2010, 10:46 AM
David,
I tried to call Kirkham today but struck out. I will again try tomorow. What is the make of yours? Does anyone have a part number for a fuel log or feed that fits?
Old 01-27-2010, 11:08 AM
DougD's Avatar
Cobra Make, Engine: Sold my beloved Shelby CSX 4068, Gessford 427 Ford
I had the same problem when fitting my turkey pan. If you're going for the original look, the commonly sold fuel logs only fit 3-2bbls and 2-4bbls, not a single Holley/turkey pan combo. And the repro hard line from the fuel filter to the log will be wrong, too. The correct log is unique, and sits a little further back along the valve cover than the 2bbl and dual quad versions.
I purchased my log from Motorsports International in California, but I'm not sure they're still around. Do a web search for their telephone number and give them a try.
I had to hand fabricate a hard line to fit, but I'm pleased with the results. I used a repro line as a template and added the necessary length/bends to mate with my log. It eliminates the brass 45 degree fitting at the front of the log as the line goes straight into the log. Looks factory, and doesn't leak.
CSX4068, '69 Bronco, '70 BOSS 302, '87 Mustang GT, '08 Roush Trak Pak
Old 01-27-2010, 11:32 AM
Bernica's Avatar
Summitt has quite a few versions. Some are adjustable.
http://www.summitracing.com/search/?...el%20log&dds=1
Old 01-27-2010, 12:05 PM
Cobra Make, Engine: Contemporary CCX33344 with original bore 427 SO.
The single 4V Fuel log is available here
http://dearbornsteeltubing.homestead.com/homepage.html
Thats where I got mine...good guy
Old 01-28-2010, 09:37 AM
I got in touch with Kirkham motorsports today. They are sending me a little set up they make with a bracket for my fuel pressure regulator. They gave me a good deal. I can't ewait to get this thing togethere!
Chris
Old 01-28-2010, 08:44 PM
David Kirkham's Avatar
Original Shelby Owner
Sorry I haven't been in lately. I have been working on a special project.
David
Old 01-29-2010, 01:59 AM
No problem I'm all set now
Chris
