Old 04-14-2010, 07:20 AM
Club Cobra Member
Cobra Make, Engine: Kirkham/Southern 427 SO finally on the road
Default Using a remote starter switch....novice question
I have a remote starter switch that I know gets one connection to the positive of the battery and the other to the starter solenoid, I think. However, I'm not sure where that is on my 427 FE (Kirkham). Is it on the firewall or ??. thanx steve
steve meltzer
"I may be wrong, but I'm never in doubt"
Old 04-14-2010, 07:42 AM
Cobra Make, Engine: Backdraft, 302, Tremec 3550. #038
When you get it figured out, better make sure its in neutral before starting.
Kids in the backseats cause accidents, accidents in the backseat causes kids ! Good reason to get a Cobra !!!
Old 04-14-2010, 08:13 AM
MOTORHEAD's Avatar
Cobra Make, Engine: KIRKHAM 427 S/C, SHELBY 427 ALUM. STROKER
Starter relay is on the firewall. How does it have one or two small terminals?
"When Injustice becomes Law,
Rebellion becomes Duty." T. Jefferson
Old 04-14-2010, 08:17 AM
Rick Parker's Avatar
The remote is used to switch the solenoid only (on the Firewall), it cannot carry the current for the stater motor. Be sure the transmission is in neutral and out of gear. Attach one lead to the positive post (from the battery) on the solenoid, and the other attaches to one of the small posts that the smaller wires attach too.
Rick
Old 04-14-2010, 09:09 AM
twobjshelbys's Avatar
Could you not wire the transmission neutral switch into the circuit (assuming it has one)?
Old 04-14-2010, 09:37 AM
Steve, see this recent thread: DCDoug -- One more tip on 1st time valve adjusting
Old 04-14-2010, 10:16 AM
And, before you push the remote starter button, would you make sure my ex-wife is standing between the front of your car and a wall?
Personally don't care what gear the trans is in as long as it is one of the forward 5.
Thanks.
Jim
