Old 07-27-2010, 09:06 PM
Foghorn's Avatar
Cobra Make, Engine: KMS427S/C #0631
Default Kirkham coil-over spring rates
My car was delivered with 450 lbs/per inch springs on the shocks at all four corners.
Has anyone gone the extra effort to put his or her car on a set of scales to set the corner weights and ride height?
Did you have to change the springs and to what rate did you change them?
My car has a KC aluminum 482 and TKO600 drivetrain.
Thanks in advance!
Old 07-28-2010, 11:23 AM
FatBoy's Avatar
I've just had mine fully set up with corner balancing and got within 0.5kg with a 100kg driver and half a tank of fuel.
That was on the original 450lb & 600lb springs.
Interestingly, the front to rear weight distribution was 48% front/52% rear and I have a "heavy" iron 427 S/O, albeit with ali heads.
Paul
