questions
- » Blogs
- » Image Gallery
million posts!
| S |
1 |
| 3 |
5 |
8 |
| 10 |
12 |
15 |
| 17 |
19 |
22 |
| 24 |
26 |
29 |
30 |
| 31 |
08-18-2010, 05:34 PM
ca
Cobra Make, Engine: Kirkham #185, Shelby Alloy 482; sold
Sidepipe vibration isolation
For those of you that have isolated your side pipes from the frame, could you post a picture so I can see some of the isolation methods?
Dave
Advertising
08-18-2010, 06:33 PM
Average Guy
IN
Cobra Make, Engine: red Shell Valley, white stripes
I don't have a picture, but I used some rubber bushings normally used on the top stud of a shock absorber on our daily driver. Cheap and effective.
When I said I wanted to be somebody, I probably should have been more specific...
08-18-2010, 07:17 PM
ERA uses a big-ass piece of heavy rubber hanging down to a bracket that is welded on the pipe.
08-18-2010, 08:09 PM
ca
Thanks, but I was hoping for some responses from Kirkham owners.
Dave
08-18-2010, 08:44 PM
Ca
Contact Kirkham direct.
Rick
08-22-2010, 04:53 PM
How much vibration come from this? Is the purpose of this to feel less vobration as a driver or something else?
08-22-2010, 07:06 PM
Ca
The CSX cars used a bracket similar to that in Patricks picture above. The bracket was welded to the pipe and is stable in two planes, fore/aft and vertical shear (supporting the weight). It would slide between 2 tabs that were welded to the chassis and a bolt passed through the 3 pieces with a rubber tubular isolator (like a piece of 3/8' fuel line (with bolt through it) inside a metal tube about an inch long that was welded to the bracket on the pipe. It locates the exhaust pipe and dampens the vibrations and lessens the harmonics created by the exhaust impulses. Very effective.
Rick
08-22-2010, 07:16 PM
CA
Cobra Make, Engine: Kirkham, 427 side oiler
My Kirkham sidepipes have a bracket which is essentially a stand-off welded to the sidepipe that bolts to the frame. It's all factory stuff and designed to work with the car. No rubber bushing. As far a vibration.....the whole car essentialy vibrates with a 600 HP big block!! I would call the Kirkhams to sort out!
08-22-2010, 08:09 PM
ca
Cobra Make, Engine: owned Kirkham for 11 years
Hi Dave,
I remember Morris`thread on his Kirkham #259 over on the Gasholes website goes into a lot of detail for the back mount. I just checked and a good pic is on page 64 of his build site.
Are you coming up to Sears Point for SACC?
Maurice
08-22-2010, 08:13 PM
ca
Thanks, Maurice. I'll be at SAAC35 on Saturday, hope you see you.
Dave
08-24-2010, 12:54 AM
Super Moderator
CA
So I go and take pics, and then realize I haven't loaded Photoshop into my new laptop yet. I'll try to get that done tomorrow. Otherwise, you can eyeball it at SAAC.
It's a two-piece affair...one long arm welded to the pipe, and another long arm welded to main frame tube...joined together with a good sized bolt. Allows for fine adjustment of the pipe height and the long length probably provides a certain amount of flex without it being rubbery.
Jamo
