December 2025
Old 04-09-2011, 02:11 AM
Cobra Make, Engine: 1965 registered Brushed Kirkham polished stripes, 427 FE kieth craft 482 efi.ss chassis and all the go gear .
Default Brushed Kirkham + salt air.
Hi Guys,
My Kirkham lives in a CarCoon and i live on a salt water front, property .
Troubles is although i WD40 Regularly i get a lot of oxidation , although i can scotch brite most of it out , not sure its a good idea all the time....... do not want to find out one day i have gone too far !!!
Considered and purchased Shark hide but too scared to use it on all the car.
Is this normal ?? what are my options ??
Thanks in advance.
Soul.
" And them boys in them Chevy's,are going to say Pipes!!! Look at them pipes !!!- Bill Cosby 200MPH.
Old 04-09-2011, 08:05 AM
Jerry Clayton's Avatar
by the salt, you need a fiberglass car
Old 04-09-2011, 10:19 AM
mreid's Avatar
Cobra Make, Engine: Kirkham 289 FIA #690, FRPP 427 Boss engine
I'd say paint it. I mean all the originals had paint. I too would worry about the constant need to remove oxidation knowing that a tiny part of the body was being removed with each pass of the scotchbrite.
RCR GT40 SOLD to Fast 5
Kirkham #690 289 FIA
Old 04-09-2011, 10:27 AM
CobraEd's Avatar
If you have the saly misted air as is typical by most beachfronts, I would be worried about the inside of the body panels as well as just what you are seeing on the outside. You can paint the outside like an original, but you can't paint the inside now that its built.
LIFE IS TOO SHORT TO WORRY ABOUT GOOD GAS MILEAGE
________
Utinam logica falsa tuam philosophiam totam suffodiant!
________
Old 04-09-2011, 12:12 PM
SP01715's Avatar
Cobra Make, Engine: SPF1715, Roush Built 434 ci Stroker, Dart Block, Ported AFR 205 Heads... 561 hp / 547 tq, Former Roush Show Car, Completed and Prepped By Olthoff Racing.
I use Sharkshide on my pontoon boat and it will definitely protect the aluminum. If you like the look of Sharkshide it is easy to apply. You have to make sure the aluminum is clean and free of blemishes (sp) or you will be able to see them through the Sharkshide. You can always remove it with an acid wash if you want to down the road.
Old 04-09-2011, 01:58 PM
RodKnock's Avatar
Move?
Won't salt also be bad for paint?
Old 04-09-2011, 09:33 PM
Thanks,
What do you mean by the look of it ??
Is it not meant to be a transparent finish ??
Getting it off with acid wash !!! Thats gotta be scary.
Soul.
