Old 07-12-2011, 09:09 AM
Avmaviator's Avatar
Cobra Make, Engine: Kirkham #647 brushed
Default Suspension Measurements
Hey guys,
Would you guys have any measurements for initial set up of the suspension, for a 427? For example, shock/spring set up (how far down are the spring end plates on the shock housing, for ride height basically), the length on the rear tie rod/control arm bar (not really the control arm, but the bar that goes diagonally from the control arm to frame, which adjusts the toe in or out of the rear basically), and the same for the front.
I would like to get those measurement somewhat close so that I am able to drive the car of my friend's shop for a full alignment.
Thanks!
Arno
Old 07-13-2011, 05:48 PM
CC Member / Sponsor
Set the ride height to 4.25 front, 4.75 rear.
Toe in 1/8" with to span of 24 inches
Camber -1/2 degree
Castor 3.5 degrees +/- .5 but get castor even
Make sure all of the adjustments are tight.
Cubic Performance
HiTech Legends
https:HiTechLegends.com
Evolve Lubricants
https://evolvelube.com/
Old 07-13-2011, 09:41 PM
Avmaviator's Avatar
Camber -1/2 degree
Thanks Tom!
