  #101 (permalink)
Old 11-12-2012, 08:07 AM
David Kirkham's Avatar
Original Shelby Owner
We use a small piece of rubber fuel line with stainless hose clamps.
  #102 (permalink)
Old 11-16-2012, 02:09 PM
dcdoug's Avatar
If you are running original Lemans rods with cap screws, you may need to adjust the scraper for a bit of additional clearance.
www.partskeeper.com
  #103 (permalink)
Old 06-12-2013, 08:49 AM
dcdoug's Avatar
A question: the input for the oil temp sensor is 3/4 NPT, my oil temp sensor is a fairly common 6-AN size fitting. I have not found any female 6-AN to 3/4 NPT male reducers. Is there a more elegant solution than just combining several reducers?
www.partskeeper.com
  #104 (permalink)
Old 06-12-2013, 12:27 PM
lovehamr's Avatar
Stolen Avitar
How about 6an-1/2npt and a 3/4npt-1/2npt bushing? The bushing would hardly show.
Earl's 981668 Earl's AN to NPT Adapter Fittings
https://www.surpluscenter.com/item.a...name=hydraulic
  #105 (permalink)
Old 06-20-2013, 03:57 PM
dcdoug's Avatar
It had been so long since I removed the engine from the car and changed the pan, I forgot that there was an adapter for the sensor, which was still on the Canton pan I removed. Funny enough, it was a perfect fit from 6an to 1/2 NPT......problem solved.
www.partskeeper.com
  #106 (permalink)
Old 06-24-2013, 09:08 AM
Glad you got everything fixed
  #107 (permalink)
Old 06-24-2013, 09:12 AM
dcdoug's Avatar
Very nice pan and so far so good on leaks!
www.partskeeper.com
  #108 (permalink)
Old 11-19-2016, 01:01 AM
fordracing65's Avatar
I may have missed it in this thread. Anybody know the ground clearance for this pan on a Kirkham. Just wondering how low it sits.
PRIDEnJOY
  #109 (permalink)
Old 11-19-2016, 11:43 AM
rodneym's Avatar
Full Blown Member
Premier Contributor
The billet pans sit above the rails so no issues.
rodneym
  #110 (permalink)
Old 11-19-2016, 03:22 PM
Thanks. I figured it was done right.
PRIDEnJOY
