Like Tree5Likes
Old 04-16-2013, 03:28 PM
Cobra Make, Engine: KMP
Default Kirkham - now and then
My Kirkham (KMP 300) is about 8 years old. During that time I have followed some of David's and Thomas' posts about the incremental changes since then. I decided to send my car back to Provo in order to have updates installed. New suspension (with a rear anti-sway bar), electrics, gauges, pipes, insulation, ventilation, glove box and many other items were replaced with the current evolution of products.
All I can say is OMFG!!! What a huge difference. The car has not lost one ounce of it's brutal impact, but it is soooo much smoother and harmonious. It beats you up less, but handles, accelerates, stops and turns much better. I hesitate to use the term "refined", but the car just works better.
I write this to thank (and compliment) the folks at Kirkham and also to encourage others with older cars to think about updating them. There are hundreds of little improvements that add up to vastly more enjoyable car.
CSX3018 likes this.
Lew
I'm no expert.
Old 04-16-2013, 04:03 PM
Avons may be a large part of the handling difference-do you have them?
Chas.
Old 04-16-2013, 04:49 PM
Yes, before and after. Avons were a constant. As were Penske shocks.
ERA Chas likes this.
Lew
I'm no expert.
Old 04-16-2013, 05:01 PM
That's impressive testimony Lew.
Chas.
Old 04-16-2013, 06:20 PM
Cashburn's Avatar
Backdraft Racing Dealer
Great post. Love to hear evolution is positive!
IT'S NOT REAL. IT'S UNREAL.
VINTAGE MOTORSPORTS
Old 04-16-2013, 06:30 PM
Brent Mills's Avatar
Administrator
Lew, nice post....with regards to suspension and braking, can you provide more details around what changes were made? Mine is roughly the same age.
Old 04-16-2013, 11:53 PM
fordracing65's Avatar
I wish I would of gotten a glove box...
PRIDEnJOY
Old 04-17-2013, 04:42 AM
A98Coupe's Avatar
Cobra Make, Engine: #535 Kirkham 427, 427 Side Oiler
David,
Does this mean there is a used set of original style suspension & brakes going spare? I would be very interested in buying it for my car KMP535 - if it fits?
Stuart
Old 04-17-2013, 08:48 AM
I kept the billet suspension arms that came with it originally. David said that upgrading to the new ones would not provide a big bang for the buck. Barkes were also untouched (but I did add bellows caps to the resevoirs earlier and they made a big difference in pedal feel. Probably due to less water contamination.)
Changes:
1. new rear half shafts
2. addition of rear anti-sway bar
3. new ceramic coated stainlees steel pipes
4. gold foil engine/trans tunnel insulation (see pix on the coupe thread)
5. install glove box (it seems unimpoirtant until you have one)
6. relocate battery to trunk/use smaller light weight battery)
7. change diff from 3.31 to 3.54 (I have the TKO with the .81 OD)
8. route frsh air ducts from brake cooling inlets on each side of radiator opening in the body rather than inside the radiator opening
9. Installed Kirkham gauges with fuel level indicator inside speedo. (Required installing fuel level sensor in tank, but tank was off car do rear anti-sway bar install)
10. They also went over every nut and bolt, replaced loose rivets and just tweeked little things here and there.
My list of requests was a lot longer, but David steered me clear of things that, while sounding cool, really would not make a cost-justified improvement.
The above list seems very minor, but those little changes really transformed KMP 300 into a really nice car.
If David is reading, he may have a better recollection of what was done. I may have skipped a few mods.
Lew
I'm no expert.
Old 04-17-2013, 10:24 AM
Rick Parker's Avatar
You must have installed a small block too
Old 04-23-2013, 07:40 PM
Cobra Make, Engine: Kirkham - KMP493
Did you put air conditioning in it and arm rests too, you pansy
Old 04-24-2013, 02:27 PM
David Kirkham's Avatar
Original Shelby Owner
Coming from the pansy who ran his motor so hard he broke his block!
Chris, you are the best
CSX3018 likes this.
Old 04-24-2013, 02:31 PM
There were other things we replaced on Lew's car. I really can't remember now. When a customer's car comes in for--really about anything--we replace all sorts of parts. We have just figured out how to make things better over time. Some of the original parts really weren't that great (like the steering) and were in need of an upgrade. I would imagine we updated Lew's steering and didn't even tell him
We go through the entire car and update nuts and bolts and little parts. Come to think of it, we updated his e brakes as well.
CSX3018 and Bxx1 like this.
Old 05-03-2013, 07:54 AM
csx4017's Avatar
Cobra Make, Engine: ERA#520, Roush 427SR
Dave, I have a CSX4000 and the rear suspension bushing squeaks are non-stop. I have pulled pivot bolts and lubed with minimal results. In emails with Nick he has informed me of his and your use of bronze lubed bushings. I believe this is the answer. Looking at your front and rear geometry it appears your A-arms would bolt right in ?? The rear sway bar is another story...........Are you providing any components for the 6000 series ( besides bodys )
Old 05-06-2013, 03:32 PM
I am not sure at all what parts of ours would fit on your car. Shelby changed the suspension many times on their cars over the years. However, if your car is CSX4017 then it is a very early car and I imagine our parts would work. We use bronze bushings and Teflon lined rod ends throughout the entire car. In theory, our parts should fit if their suspension was made to original specifications.
We have made differentials, steering components, and other parts over the years for Shelby.
Old 05-07-2013, 03:52 AM
csx4017's Avatar
Thanks Dave........Not so early....Built in Feb 2007 at HST........
Old 05-15-2013, 11:32 AM
If you look really closely, you can see the rear sway bar, the glove box and the new gauges.
Kirkham Cobra - YouTube
Just kidding. But you can see how my blue car looks different than a bare alumnium car. The video is from a recent Ferrari event. The Kirkham got the most attention of any car.
Lew
I'm no expert.
Old 05-15-2013, 12:19 PM
Cobras usually do, must make the Ferrari guys mad...
PRIDEnJOY
Old 05-20-2013, 10:18 AM
Cobra Make, Engine: Kirkham, 482 CID Keith craft engine with sdi fuel injection
Default Upgrades
This info really helps. I just bought the black and red Kirkham that was in the Maroon 5 video. It is a 2004 and I went over it with Darren Friedman and he suggested I ship it to Provo as well. Some of my gauges and electrical aren't working, and definitely could use an overhaul. I think this thread swayed me toward sending it in sooner than later. Thanks.
Dr Daniel Slaton
Westlake Village Animal Hospital
Old 05-20-2013, 10:32 AM
[quote=DOGTORS;1244833]This info really helps. I just bought the black and red Kirkham that was in the Maroon 5 video. It is a 2004 and I went over it with Darren Friedman and he suggested I ship it to Provo as well. Some of my gauges and electrical aren't working, and definitely could use an overhaul. I think this thread swayed me toward sending it in sooner than later. Thanks.[/QUO
You probably should send back to Kirkham, that car was burnt to a crisp in the video...
PRIDEnJOY
