Like Tree7Likes
Old 02-15-2017, 03:12 PM
Cobra Make, Engine: Kirkham
Default Suspension alignment
How I set up alignment on my new Kirkham 427, with an opportunity to showcase the really fantastic suspension of the Kirkham. Not just pretty to look at, but really well engineered and a pleasure to work with, compared to my previous work on panteras and mustangs and old corvettes.
This seemed to work for me. I give no guarantees to safety or validity of this technique. This is my experience as an amateur.
As a recreational mechanic, I do not have ready access to a fancy alignment machine. Years back I bought the Fastrax, which is powerful but probably not as precise as a laser. But with the right amount of effort and time, seems to give pretty good results.
This device basically has a level on it, so you can measure camber, which is just how many degrees off the wheel is from the vertical. By holding the device on the wheel and measuring camber at 15 degrees of turn-out and comparing to 15 degrees of wheel turned-in, you can also read caster with the same level.
It also has adapter arms to measure toe in, with some futzing. I have found a bungee cord will hold the device to the wheel while I measure with a tape measure to the opposite tire. I measure to the edge of the tread. This is probably accurate to a sixteenth of an inch if I am careful, judging by my own unofficial testing with repeated measurements. It actually is surprising how consistent the measurements can be.
Old 02-15-2017, 03:14 PM
First I set ride height on the front and rear. Just under 6” at the rear, and 5” at the front. Others may want theirs lower. This is easily done by adjusting the Penske coilover shocks. Of note, to get the rear below 6”, the spring ends up loose at full droop (when jacked in the air). But when the weight of the car is on the suspension, the spring is under compression. Apparently this is common with some coilovers.
Although I have a spanner wrench for adjusting coil-overs, actually don’t need one on the Kirkham. If I wanted to make the ride height much higher, then I would.
With a 4 wheel independent suspension, the next thing is to find the long axis of the car/frame. I am not entirely sure how to do this on a car with an irregular unibody, like a Pantera, but with an original-style framed Cobra, the main tubes are a good point of reference. The frame is really nice and square (parallel main tubes) on a kirkham. I used a level to measure a fixed distance (21 inches for me) perpendicular to the main tubes on each side, and put marks on the floor so I could draw a line that represented the long axis of the frame but alongside the body. Shown in this image by the green tape marks on the floor.
1985 CCX likes this.
Old 02-15-2017, 03:15 PM
Next I want to set the long axis of the rear tires to be parallel to this long axis of the frame. The tape marks on the ground show me the long axis of the frame. I need to determine the long axis of the tire. I came up with an idea to use string under tension, although others have apparently also used this from what I hear.
I put a heavy jackstand behind the car, towards the center, and a second in front of the car. I tied a string between those jack stands, so the string is coming from inside the back of the rear tire and running toward the front. The string should be under tension, not loose, so it is a straight line. Then I move the front jack stand so that the string is just barely touching the front of the rear tire, so I know the string is along the axis of the rear tire. So now the string is perfectly parallel to the long axis of the tire.
I then adjust the toe of the rear tire until I can get the string to be parallel to the frame axis, which is on the floor on the green tape marks. The rear toe-rod (probably the wrong name) is easy to turn to make this adjustment. My floor is vinyl tile, and if I put a thin piece of cardboard under the tires, the wheels slide easily, so I can move the tire and not have to rock the car to be sure the tire has moved. If I was on pavement or unfinished concrete, I would have to rock the car back and forth a bit to settle the tire to be sure the change in the suspension is in effect. Hope that makes sense.
At first, I set the rear toe to be “zero.” This helps align the front tires later. Even later on I will add toe in.
Old 02-15-2017, 03:17 PM
Next I set the rear camber. On the Kirkham, this is easy. First measure with fastrax. I was positive 1 degree. At the rear suspension, when the car was delivered, the only loose rear suspension nuts were on the toe link and the upper heim joint/rod end at the rear carrier. (the rod end attaching the upper control arm to the rear hub carrier) All the others were tight, so I figured these shouldn’t be adjusted. To adjust the rear camber, (after jacking up car, placing jack stands, and removing rear tire) unbolt the rod end at the top of the rear upright and disconnect it from the upright. Then spin the rod end in or out to adjust camber, then re-attach to the upright. It takes longer to type these words than it takes to do it.
Then put the tire back on and lower the jack (after removing the jack stands). Remeasure camber with fastrax. It took me two times up and down to get a little more than 0.5 degree negative camber, which is what I wanted.
When it is where you want, you tighten the adjuster nut on the rod end.
As mentioned before, I put a piece of cardboard under the tire, and my floor is vinyl tile, so the tires will move with the weight of the car on them. So I can adjust toe while the car is on the ground. For camber, I have to jack up car, remove wheel, adjust camber, then put tire back on and lower car, each time. I also roll the car a little front to back to make sure nothing is binding from jacking up and down. So adjusting camber takes a few tries to get it just right. But not hard to do.
I found if I check camber when I first lower the car off the jack, and then check again after rolling car front and back a bit, there is a slight bit more negative camber after rolling. So I can’t trust the vinyl floor tile and cardboard to fully settle the suspension when coming off the jack.
Old 02-15-2017, 03:18 PM
Now that I am happy with camber, I double check the toe in with the fastrax. Strap the fastrax to the rear tire with a bungee cord, and use the legs to measure with a tape measure to the front and rear of the opposite tire. I picked a spot on the edge of the tread to measure to. This should be equal on the front and back of the tire, meaning the tires are parallel and toe in is set to zero. Which is what I want for now.
Old 02-15-2017, 03:20 PM
Now to the front suspension –
Front tire camber is really easy to set on a Kirkham. The lower control arm has these neat adjustments at the attachment to the frame. The rod ends can be pulled in or out of the control arm by turning the hex heads on the lower arm, as in the picture. In addition, by varying how much the forward or rear rod end is moved, can adjust caster (the forward rod end should be extended out further to decrease caster). At least I think that is how it works, and it worked well for me.
I could even make these adjustments with the car on the ground, as long as I had cardboard on my vinyl tile, so the tires slide really easily. I think if I jacked up the car, I might have to roll it to settle the suspension, but once on the ground, suspension changes don’t seem to need the rolling back and forth since my floor is so slippery and the car is pretty light, even with engine in.
Old 02-15-2017, 03:22 PM
Finally, it is time to set front toe. First put the steering wheel in the straight ahead position in the center of the steering rack range. Then run a string again from a jack stand behind the rear tire to one in front, with the string again running just barely on the front of the rear tire, so the string represents the long axis of the car and the tire (since rear toe is currently at zero). Now measure the distance from the string to the front and then also the back of the front tire. If the distance from the string to the front of the tire is the same as to the rear of the tire, then the front tire is parallel to the rear tire and the long axis. Rotate the tie rod so that the front tire is perfectly parallel.
After setting the toe of both front tires to zero this way, I attached the fastrax to one of the front wheels with the bungee, and then used the adjusting legs and a tape measure to check toe-in by measuring at the front and the rear across the front tires. I was lucky (or skilled) and got the same number for both measurements, confirming the tires are at zero toe, and parallel to the long axis of the car.
Now I added a little toe in at each front tire to give about 1/16” toe in up front, and about the same in the rear. Then tightened all the adjusting nuts on the front and rear tie rods and double checked everything in the suspension.
Although maybe not as accurate as the fancy machine at the professional shop, unfortunately in my area we only have unskilled workers manning these machines, and I am happy to keep their wrenches off my car.
I aligned the suspension on my pantera about 9 years ago, and the wear pattern on the tires (admittedly only a few thousand miles) looks great, so I think I am not too far off.
here is an extra image of the front tie rod
Old 02-17-2017, 07:38 PM
Phx Mike's Avatar
Cobra Make, Engine: Ex owner of a polished Kirkham 427 S/C. Now Cobra-less and driving a mid-engine German hot rod.
Thanks for posting these. Very helpful. Is there a way to adjust the caster?
Old 02-18-2017, 07:18 AM
The typical way to adjust caster is to use shims where the control arms mount to the frame. But I was able to make slight adjustments by turning out on one lower control arm rod end while turning the other one in. The suspension on a Kirkham is really well designed. I started with 7 degrees and brought it down to 6. That is too much for a street car from what I hear but really is fine I think on this lightweight car. If you have too much caster, then it may be hard to turn at lowest speeds. But light cars seem to do well with more caster. The pantera experts say to just put in as much caster as possible.
Old 02-18-2017, 09:52 AM
Phx Mike's Avatar
Thx - I would like more on mine. Haven't measured it but return to center coming out of a turn is not real strong and I think a bit more would help straight line stability at higher speeds too.
Old 02-26-2017, 03:34 PM
here are some additional shots of front and rear suspension, for your viewing pleasure (as requested by a few interested folks)
Old 02-26-2017, 05:29 PM
When you string a chassis.......you go off of the chassis....not the location of the wheels....
Set the strings parallel to the chassis rails.....then measure at the front of the wheel and the rear of the wheel to tell you what the wheel is doing.....and adjust from there..........
Camber is set based on the temperature of the heat across the tire.....
Caster is as much as you can get away with....5+*degrees is best....as you start getting grip...power steering maybe necessary......
Morris
Old 02-26-2017, 05:33 PM
BTW....in one of your photo's......is that the brake bleed screw I see at the bottom of the caliper....???
Rob. Smith likes this.
Morris
Old 02-26-2017, 05:54 PM
1795's Avatar
Morris,
It does look like that in the first photo of a caliper that the bleeder is on top and in the last photo that includes a caliper the bleeder does appear to be on the bottom. Good catch, I have looked at these several times and did not pick up on that.
I agree with coming off of the frame (which hopefully should be straight) to establish straight lines from which to align the tires. Sage advice.
Old 11-05-2019, 08:40 AM
Cobra Make, Engine: NAF 427
Great post jkg2101.
What did you set the REAR SUSPENSION UPRIGHT CASTOR at ?
Thanks for your help.
Greg
Old 11-05-2019, 02:55 PM
Gaz64's Avatar
Greg,
Rear suspension geometry has no characteristic that is defined as caster. A caster angle applies where the wheel pivots around a steering axis - the rear wheels don't do this (except for the small amount of movement that's used to adjust toe).
Unless you have 4 wheel steering.
And the only way to measure caster is to sweep the "steering" 15 degrees to left and right first.
Old 11-05-2019, 05:57 PM
Originally Posted by my427cobra View Post
Great post jkg2101.
Greg
What you really want to know .....is what is the bump steer on the rear.....
This has the biggest affect on the rear as power is put to the ground and the chassis squats down and the wheel steers in or out as it moves thru the bump and rebound travel.....
Only .015” thousands of a inch....is allowable per inch of travel in bump or droop....
Morris
Old 11-06-2019, 06:56 AM
Cobra Make, Engine: SPF 1233-396C.I. Windsor
Morris,I am guessing the caliper is universal left or right and has internal crossover tubes. We see this typically on rear calipers that are square bore.(not staggered).
Mike Beamish / Northern Racing Products Superformance service & installation.
Old 02-21-2020, 02:15 AM
Boy ..those shocks are at a steep angle... that will require a heavier spring. I did a lot of work on mine to make the shocks as close to vertical as possible... good luck with that set up.
Old 02-21-2020, 08:10 PM
hauss's Avatar
When you lay down the shock it allows it to be longer witch helps with the action of the suspension I am no expert but the motorcycle world found this to be true back in the 70s I do not own a kirkham but personally I really like what I am seeing.
