Old 10-22-2018, 11:30 PM
Cobra Make, Engine: Alum 427 S/C with KC FE 482 Shelby
Default Rear rims / whells
intend to replace rear wheels on my KMS 427 as I noticed that handbrake mechanics damaged the inner rim surface - probably small stones got inbetween handbrake assembley and rim (now corrected cause as good as possible via grinding away "contact surfaces of handbrake assembley) - Forgot to take pictures........sorry
So the questions is:
Anyone aware which wheel producer provides rims to KMS for 427 S/C so that I can get exactly same wheels?
I shall not forget to state: In all the years of ownership that was the only tiny hick-up I had as far it concerns my KMS - Love the car and the build quality!
If any hick-upīs with the car (and even those where / are almost negelectable): All of them related non Kirkham but more or less simple engine / clutch issues......
I shall appreciate your support
Carsten
Old 10-23-2018, 10:18 AM
No....but BBS makes a Center section that works for the KMS Hub and then you can get any size wheel you want......
We use the 18” BBS wheels on KMP259
Morris
Old 10-23-2018, 11:46 AM
Thanks for the feed-back Morris!
I belong to the group of happy ignorants sticking to 15 dimension.....so I need to hope for further advice from that section.....
Old 10-23-2018, 03:12 PM
RodKnock's Avatar
The tolerances are tight, so I'd say all it takes is a bump in the road to damage the inner wheel surface. Same thing happened to mine.
Trigo wheels are the replacement for KMS.
Old 10-23-2018, 11:17 PM
rodneym's Avatar
Full Blown Member
Premier Contributor
Nc427,
Am I reading that right? You want to replace the wheels due to a tiny pebble scratching the inside of the rim?! Those tolerances are super tight. It WILL happen again. The only time I see my grooves are when the wheels are off.
rodneym
Old 10-25-2018, 12:38 PM
Granted input is helpful - thanks a lot!
Yep, tolerances are very tight.........as indicated i grinded a certain portion of the handbrake assembly down -> works technically just fine since 4 years -> still I had something stuck between handbrake assembly and wheel stuck (probably a small stone) and the scratches on the inner side of then wheel are deeper than I like them to be Yep, everything is technically still fine since four years but I want do something good to my KMS 😀
So I understand Trigo are the ones I need to go for.........shall check
Thanks again to all contributors
