questions
- » Blogs
- » Image Gallery
million posts!
May 2024
1 |
5 |
8 |
12 |
15 |
19 |
22 |
26 |
29 |
30 |
31 |
03-19-2004, 09:52 AM
IL
Cobra Make, Engine: Kirkham #259
Brent
BTW if you do decide to use the duel pump method..... Mech and Elect.......
You need to add a check valve in the tee output of the mech pump.... so it doesn't lose pressure pumping to the carb and back to the electric pump at the same time....
Glad to see you're on your way.....
Morris
Morris
Advertising
03-19-2004, 01:22 PM
Super Moderator
CA
Michael
It may have also been sparked (bad word) by a thread over at Gasholes where I asked Pat to make me a cover to go around the pump/filter so my stuff wouldn't go banging into it...something we noticed during the Monterey Historics last year when we filled the trunk. The Original Gashole made a nice arruminum thingy that attaches in front of and behind the pump/filter against the side panel, and has holes for observation/ventalation. Two screws hold it. I've yet to install it semi-permanently due to laziness and a desire to install quick release fasteners, but it'll work like a charm by all appearances. When Little Davey saw it, he noted the same thing you referred to. Nice thing is it's easy removal.
Probably best to move the whole affair outside the trunk in the final analysis. Not everything from the 60s was necessarily a good idea.
Jamo
03-19-2004, 01:24 PM
GA
Cobra Make, Engine: 2 dr roadster, V-8, 4 spd.
Now y'all got me freaking out about it as well.
03-19-2004, 01:28 PM
Super Moderator
CA
Blowing up or having stuff smash into the pump or both?
If you blow up...you won't be around to care.
Jamo
03-19-2004, 02:00 PM
NY
I would rather explode in a very correct replica.
03-19-2004, 02:41 PM
Cobra Make, Engine: KMP
Just to chime in: David K says that he recommends that no fuel lines/pumps/filters be in the trunk. On the race cars there was never anything in the trunk. On these cars, people actually put stuff in there that could bang against hthe fuel mechanicals. That stuff does look cool when you open the trunk, but I think David K's reasoning makes sense.
Lew
I'm no expert.
03-19-2004, 05:08 PM
Super Moderator
CA
Hmmmm....I guess folks just started using the trunks as trunks.
Buckley will be selling the pump/filter cover like the one he made me for $159.99 each.
Jamo
03-19-2004, 09:00 PM
ME
Cobra Make, Engine: Original ERA 427sc, Powered by Gessford
No need to worry, by the time your car is finished, there won't be any fossil fuels left to explode
Replica is not a dirty word.
03-20-2004, 05:15 AM
This is a comp car setup, if that helps
03-20-2004, 05:17 AM
Same car, Factory Comp car
03-20-2004, 05:19 AM
Note dry sump too
03-20-2004, 06:06 AM
SC
Brent,yes my pump is outside under the car.I like this setup better and it makes sence to keep it outside.I am putting in my aluminum differential today so hopefully I will not booger up something up under there. chuck
03-20-2004, 07:41 AM
GA
After YEARS of selling them with the pump/filter in the trunk, how can that not be recommend any more?
The only way this is a bad idea is if you carry bowling balls loose in the trunk - - soft luggage ain't gonna hurt anything.
Next thing you know, anything with more than 300HP isn't going to be recommended either.....
These are Cobra replica's for darns sake! I'm not in love with the idea of sitting at a light with 40 gallons of race fuel behind me in a non fuel cell type tank either, but I am sure I will take it into consideration when I drive it. I have been practicing my vehicle exits lately - the life I save may be my own. Then again, Masten Gregory has always been a hero....
03-20-2004, 08:07 AM
Cutting the side holes? I hear you Brent, last time I cut something, twice, and it was STILL to short.
Ernie
03-21-2004, 03:36 PM
Administrator
Wa
So, it is outside and low near the rear housing as far as I could tell and fully plumbed. Just an oversight on my part.
Bled the brakes today and scooted the thing up the driveway a bit and let her roll...She stopped...Had my hand on the ebrake just in case.
03-21-2004, 04:31 PM
SC
It's hard to argue with you Pat; 454 cubic inches,570 HP,2200 lbs,butt 8 inches off the ground,head at SUV bumper level,no air bag no side protection,but my fuel pump is mounted outside the trunk so I can sleep good tonight. chuck
03-21-2004, 07:54 PM
Super Moderator
CA
Chuck
Hehehe...
Sort of makes Pintos seem like safe vehicles, don't it?
With apologies to Chief Joseph, I no longer give a sh!t...forever.
Jamo
03-21-2004, 09:23 PM
By the way Brent, whats the status on your "unknown" cobra?
Ernie
03-21-2004, 11:15 PM
Administrator
Wa
Ernie, she's been sold.
Thread Tools |
Display Modes |
Linear Mode
