Old 10-18-2004, 06:59 AM
R U YELLA's Avatar
Ed Digges
Cobra Make, Engine: Kirkham #328 w/ 390FE
Default The ULTIMATE aluminum cleaner!
I surfed the net last week in search of an aluminum cleaner. I did a search for "aluminum" and "oxidation". I found a few sites but one really stood out. It is a new product called ALUMA KLEEN by BioKleen. You can find it here:
http://www.biokleen.com/store.cfm/bi.../ID=227#browse
I called the tech line & actually talked to the chemist that developed the stuff. What I liked about what he said is that it will not hurt the aluminum and if I ever decided to paint the car the solution does not have any waxes in it. All you have to do is spray it on & let it sit for a minute. Next all you have to do is wipe it off or hose it down (I wiped it off). There is a great noticeable difference. I only got the 32oz size to test but it wasn't enough to get it the way I wanted to look. It will take a few times to get the color to look consistant and get rid of the drip lines.
If you have a sprayer that acts like an atomizer, that will be better and cause less runoff. I also ordered another gallon of the stuff. It removes grease marks & finger prints as well. After you have sprayed & cleaned the whole car once, I would suggest spraying some on a towell and cleaning the car that way. Way better than Windex.
One note of caution: Try not to get it on other metals. I let some sit on the gas cap too long and now there are spots. I suspect that I will just have to polish it.
I will post som pics later.
Later
Ed
Old 10-18-2004, 07:44 AM
BMK's Avatar
BMK BMK is offline
Ed
I'm thinking you have an aluminium/aluminum finish on your Kirkham body there?
Or are you using this on wheels and other aluminium/aluminum bits -
Have been using 'Aquasol' over here. Its a paste in a toothpaste type tube that is wiped on/rubbed and then polished off. It has cutting ability.
There's also a 'Chromebrite' in a yellow tin on a wool that is pulled out and used the same way. This latter is ideal once the aluminium/aluminum is cut and polished.
Bernie
Bernie Knight
Old 10-18-2004, 07:54 AM
R U YELLA's Avatar
Ed Digges
Bernie - Yes it is an aluminum finish but this stuff was made for snowmobiles! Go figure? You can use it on any aluminum surface. The nice thing about this stuff is that you spray on and wipe off. There is no rubbing what so ever. If a spot still looks bad then you just spray again. It also protects the metal from future oxidation. I'll have not yet seen that since I just started to use it. I also got the polish but that will be later this winter.
Later
Ed
Old 10-23-2004, 12:58 PM
R U YELLA's Avatar
Ed Digges
The darker line in the front is the before. I put a piece of tape down before I used the cleaner. Big difference!
Later
Ed
Old 10-23-2004, 01:00 PM
R U YELLA's Avatar
Ed Digges
One more.
Old 10-23-2004, 01:02 PM
R U YELLA's Avatar
Ed Digges
The bottle.
Old 10-23-2004, 07:09 PM
Ed - just ordered some.
Old 10-24-2004, 09:48 AM
ENTDOC's Avatar
Ed.isn't the gas cap aluminum also? chuck
Old 10-24-2004, 04:57 PM
I thought it was chrome....
Old 10-24-2004, 05:08 PM
BMK's Avatar
BMK BMK is offline
Looks good. I have a lot of aluminium/aluminum in the interior.
I have used the CRC with a dish pad to take the harsh shine off. Guess this is the opposite to what the Sled Brite does. Would be good for my wheels etc. though.
Bernie
Bernie Knight
Old 10-25-2004, 05:09 AM
R U YELLA's Avatar
Ed Digges
Bill - When you do yours, test the stripes. This stuff might take the stripes off. And I hope you bought at least a gallon. The one bottle was not enough. Missed you at the Grease Up!. You better show next week.
Later
Ed
Old 10-25-2004, 07:16 AM
Cobra Make, Engine: shell valley, all aluminum 540 ci chevy
I'll bet this stuff has acid in it. I have used diluted acid for years to "brighten" aluminum. Don't get it on anything but aluminum and don't get it in your eyes. -Bob
Old 12-11-2004, 02:58 PM
Ed, are you still happy with this stuff? What are the effects when you rinse and it gets on chrome, quick jacks, etc?
Old 12-11-2004, 07:52 PM
R U YELLA's Avatar
Ed Digges
Yes I am very happy with this product. At first I sprayed it on the body and let it sit for 30-45 sec and wiped off. By doing this It left drip marks. I found that if you sprayed it on and let it sit for 5-10 sec & then wipe off did a lot better of a job. Do not spray directly on chrome. It will leave spots. If you wipe it off quickly it won't do anything to the chrome. This stuff makes the aluminum look brand new with little to no effort.
Old 12-11-2004, 08:38 PM
R U Yella,
The cloth used to wipe, is it damp or dry? Do you keep ringing the cloth in water to dilute the solution as you wipe the body?
Old 12-12-2004, 02:30 AM
DP935's Avatar
Cobra Make, Engine: Shelby CSX 4236 with a Shelby aluminum 427 "It's The Great Pumpkin"
could this stuff be used on a aluminum engine?
Old 12-12-2004, 03:40 AM
Big-Foot's Avatar
Cobra Make, Engine: RCR GT40 #45
If I had the bucks for a Kirkham, I would ask Kirkam if this stuff is safe to use on their cars.
I'm thinking it's a diluted acid as well. I've used something that cleans aluminum and removes oxidation in the past on my motorcycle engine. It worked fantastically! The only kicker was that the aluminum I used it on now oxidizes 10 times worse and 10 times faster now and you have to keep chasing after it with the cleaner (acid). I finally got smart and started spraying it down with WD40 after cleaning it and then wiping it all down. Now it still oxidizes, but at a much slower pace, but the WD40 attracts just that much more dust/dirt.
In the long run, I took a negligible annoyance and turned it into a major headache.
Regards - Randy
RCR40 #45 http://www.GT-Forty.com
Old 12-13-2004, 05:50 AM
R U YELLA's Avatar
Ed Digges
I would test it on the engine first but I would think so but you have to watch out for other stuff like chrome. It did a nice job on my gas cap that I had to re-polish. I do not think that it is an acid. This is something new on the market but was made to clean snow mobiles! I use a dry cloth to wipe up. It does nothing unless it puddles on the metal so if the cloth is damp with the solution it will do nothing. It also protects the metal from oxidizing.
Old 04-28-2005, 06:24 PM
David Kirkham's Avatar
Original Shelby Owner
Smile
I would be careful about that product and I am very curious about the long term comments on it.
We use good ole Windex on our cars...but I am ALWAYS looking for something different and better to make it easier.
Old 04-28-2005, 06:35 PM
Cobra Make, Engine: Almac Cobra 427R
Looks like you need to buy some David - and put some on a piece of aluminium in the corner of the shop?
