questions
- » Blogs
- » Image Gallery
million posts!
| S |
1 |
| 3 |
5 |
8 |
| 10 |
12 |
15 |
| 17 |
19 |
22 |
| 24 |
26 |
29 |
30 |
| 31 |
02-27-2005, 09:42 AM
Banned
Stainless Steel Frame Question
From my understanding of materials, etc it seems you can just change the frame metal from one type of metal to the other without making other changes to accomodate the new metal:
Examples where the new material has to be worked with differently or things won't work right
stainless steel brake lines vs steel
aluminum frame vs steel (C6 Z06)
titanium exhaust (2001-2004 C5 Z06)
So my question is what was needed to be changed for the stainless steel frame for the Kirkham cars?
What are the differences of the stainless vs the steel (other than the no rust factor)
What's the weight difference?
Is the SS more rigid? If so, more prone to cracking instead of flexing?
I am not trying to make it look bad, I just want to underdtand it better.
Thanks.
02-27-2005, 10:54 AM
PA
Cobra Make, Engine: FFR2100X (Mk1) - Whipple Blown 331
There is a huge difference in the strengths of various steels but less spread in the stiffness. I have no idea what steels Kirkham uses for the regular chassis or the stainless chassis I could not find it on their website. Here is a good link to MIL HDBK 5, which is an Aerospace materials design document. If you look in chapter 2 you will find the properties of virtually all high grade steel and CRES (corrosion resisting steels).
http://www.grantadesign.com/cgi-bin/...IL5-H.xml&br=3
Mike
02-27-2005, 11:54 AM
rsimoes,
Concerning the uses for the car that you have already stated, you will never begin to stress the frame any where never its potential, steel or stainless.
My KMP has a 304 stainless frame and I believe David K. said it is 100 lbs less than the steel frame, but call David and confirm. I am sure you know that the current steel frames have a thicker wall thickness than the original CSX3000 cars. All the frames have the same external dimensions as the original cars, want to know more dial up Kirkham.
The last Kirkham Summit had an in depth talk on Steel Suspension vs Aluminum and the metallurgy between the two as well as the weight savings. Also less unsprung weight.
If you are wanting a pure race car talk to Morris (KMP 259) he has a SS frame, 750hp race motor and an all aluminum suspension except steel lower front A arms, Morris is looking for 180mph in the car, Ask David K. about the car. Morris is a retired Professional Racer and his skills match the potential of the car. So if a Professional is willing to risk his pink body with a stainless frame rest assured it has been engineered properly. His brakes also are not stock issue.
Your questions need to be posed to Kirkham they are the experts on the engineering of their car or are you from the Corvette Club baiting us?
02-27-2005, 12:25 PM
Banned
That's for the answers. It's good to know. I am not questioning that Kirkham did their homework, I'm sure they have. I am just curious about these details.
Thanks!
Follow up question.
Are they any drawbacks to the stainless steel frame, other than cost?
02-27-2005, 01:48 PM
Thanks!
Follow up question.
That is BB vs SB each has his own opinion. Some prefer the flex rates of steel over stainless, did not affect Morris in his decision for a race car. Again for the average Joe, it is personal preference, you will always find someone to argue, My Dog is better than your Dog"
I like the stainless and since mine is not patterned after the CSX3000, I don't care. My fuel/ oil hoses are modern HS-79, fittings super nickel aluminum etc. As many modern advances I can put on the car and still keep the flavor of the CSX3000, in my opinion only.
02-27-2005, 06:31 PM
FL
David told us at the last summit, the stainless frame is simply for the no rust factor and the "wow" factor. It has no advantage/disadvantage other than that over the standard steel frame.
Sal Mennella
02-27-2005, 10:02 PM
ID
Cobra Make, Engine: KMP 393 $27 S.O. bored and stroked to 482
Sal, I can back you up on that, I was standing about four feet from David when he said it, but it is cool.
Sideways
02-28-2005, 06:49 AM
IL
Cobra Make, Engine: Kirkham #259
It very difficult to drill a hole in......
Morris
02-28-2005, 07:10 AM
FL
Here's the new version of the E-M chassis, about a third of the way down the page:
E-M photo page
It's all SS (no pun intended, honest  )
02-28-2005, 08:38 AM
TX
Cobra Make, Engine: Scratch build......a little every day.
Morris
Use Cobalt drill bits, makes it a little easier. I know, I'm working on a Stainless Steel frame and a center punch and those bits sure help.
Dave
55 mph is unsafe at any speed. Huh?
02-28-2005, 08:40 AM
[quote]Originally posted by Morris
It very difficult to drill a hole in...... [/QUOTE
Hi Morris,
Thanks for giving us a primer on how to do it properly, hope I did not speak for you, just trying to give rsimoes an illustration. I try to be objective with this stuff and not fall into the trap of one is better than the other, its preference as far as I am concerned.
Gary
02-28-2005, 01:46 PM
Cobra Make, Engine: Kirkham 427SC, 427 SO from the Fliptop
100 lbs that s a big deal....is that correct?
04-22-2005, 05:22 PM
Ut
The weight difference between a stainless and a steel car is now only about 15 pounds. Because of supply issues, we now use thicker stainless tubes (other than the main rails) in most of the other tubes in the car. The first stainless chassis were really light. Now, they are quite similar. We helped to make up for that with the new aluminum hood, trunk, and door frames. That saves about 20 pounds right now over the steel and stainless counterparts.
We use 304L stainless on our stainless chassis cars. The real difference is the stainless is really cool and the steel is much less expensive. Strengths are quite similar and stiffness is quite similar. Stainless just looks cooler. My new car is a stainless steel chassis car.
David
12-03-2006, 01:16 PM
Banned
Can you feel the difference in the chassis when you drive them both back to back? (assuming both cars are close in suspension settings, etc)
12-04-2006, 08:11 AM
Ut
No,
I am not that good of a driver! Maybe Morris, or Mario Andretti could tell.
David
12-04-2006, 08:45 AM
You can definitely feel the difference. It's hard to describe - it's kind of like wearing your lucky underwear.
Lew
I'm no expert.
12-04-2006, 09:21 AM
Cobra Make, Engine: Superformance, Roush 402R, Kentucky Cobra Club
Does the aluminum body touch the frame and if so does stainless help there in terms of dissimilar metals interacting?
12-04-2006, 10:20 AM
Banned
What do you mean?
12-04-2006, 11:17 AM
Banned
No,
David
I guess what I was trying to get at is when moving from one surface to another at a different angle, let's say a steep driveway, where you come in at a 45 degree angle to be sure that you won't scrape the front, so one wheel hits at a time. As the front wheel climbs the driveway, and the opposite side rear wheel is still on flat pavement, could you feel a difference in the frame torsion between the stainless and the steel?
I had a friend that I used to visit with a couple different Corvettes with a real steep driveway as described above. I remember that with my 1993 Vette, it was like jello, you felt the car's structure completely twist as it flexed going up that driveway, while the 2004 Z06 I had later would feel like it was carved from a chunk of steel. I think it would have picked up a wheel off the ground before it gave in this stress. The difference between these two generations of vettes is significant. . .
Furthermore, I assume the stainless is thinner than the steel in order to be lighter, since I believe SS is stronger than steel, is this assumption correct?
12-04-2006, 12:00 PM
"I assume the stainless is thinner than the steel in order to be lighter, since I believe SS is stronger than steel, is this assumption correct?"
There are only about a billion variations, which one were you referring to?
The addition of atoms to combat corrosion typically does NOT improve strength, but it does corrode less.
I would happily yield to a metallurgist, but I believe (as opposed to know or think) that stainless alloys are softer and less strong depending on how and what you measure. But they can be specified to be strong enough for a given application.
It does not rust (not technically true, but practically so) and it looks great. Kinda what ERA said. I best get out of here before an SPF'er gets 'whooped' up on. ;-) Those ERAs look mighty fine.
Ciao,
