Old 07-18-2005, 04:30 PM
Cobra Make, Engine: Kirkham/Southern 427 SO finally on the road
Default Kirkham with Southern ignition problem
I have a Southern 427 SO in my KMP 174, 6AL MSD box, 750 cfm Holley and Kirkham’s installed Holley electric fuel pump. I was using the distributor that Parham sent, but the car was suffering from suddenly dying at the stop light (even under very gentle deceleration) and dieseled unless the idle was decreased to where it was barely enough to keep the car alive. If you increased the idle, I think you were “in the primaries” and it would always diesel. After speaking with a couple of folks, I concluded the problem was the ignition timing (tho’ other theories were prevalent). Therefore, I wired the weights in the distributor and thus disabled the distributor's mechanical advance. Next I purchased a “timing computer” from MSD. It allows you to set the advance and the number of RPMS when it is all in.
With the unit correctly wired in, the car is very difficult to start unless the total advance is about 38° or so, and at 40° it sounds like it is exploding fuel in the sidepipes when you accelerate, and it diesels badly. The car seems worse than it was before the changes were made.
Another issue, and possibly related, is that the car (and this was before the MSD computer timer, which I’m sure is not a suspect for this problem) would spontaneously lose power on the freeway if the electric fuel pump was off. A quick glance at the fuel pressure gauge revealed that the pressure had fallen from about 6-6.5 to about 3. Indeed, kicking the electric pump back on from the dash switch rejuvenates the engine and it’s fine. Doesn’t occur with a light load (low RPM street cruising, or brief accelerations instead of a constant 4K RPM load). What’s going on here? It had been suggested that some of the issues here were related to “vapor lock”, but I’m not sure this issue is, as it happens even in 40° ambient temps. Not sure if the stalling and dying at the lights is related to vapor lock either.
Thanx for any help I can get.
steve
steve meltzer
"I may be wrong, but I'm never in doubt"
Old 07-18-2005, 06:31 PM
Steve,
What is your idle rpm? Mine is at 1000, but I could probably go a little lower, but not much. Also, what air cleaner do you have? I noticed that when I went from the Hellings and Stellings foam to the K&Ns, I don't have the stalling during quick stops. The rpms dip, but the car continues to run and recovers. On the fuel pump, mine does the same thing. I guess the mechanical pump can't pull enough fuel through the electric pump to supply the engine under load. I just keep the electric on at all times and have had no problems.
Old 07-18-2005, 06:40 PM
Stator?
Old 07-18-2005, 07:23 PM
I'm running the K&N, so that's not the problem. Parham said the electric pump is increasing the resistance to the flow driven by the mechanial pump..just as you said.
The stator looks good and in theory, only has few hundred miles on it. How would you test one?
thanx steve
steve meltzer
Old 07-18-2005, 07:38 PM
Cobra Make, Engine: unique 427 sc
you might check the float levels and needle/seats on the holley to make sure you are not dumping extra gas during decell and idle. look down the carb throat during idle and right after you shut it down to see if there is any funky dripping.
Old 07-18-2005, 09:28 PM
thanx for reminding me to do that.i'd thought about that and it got away from me. steve
steve meltzer
