02-02-2007, 10:09 AM
Banned
Tremec in a Kirkham
I'm pretty sure that the reverse light wires do not get connected in Cobras, but does the neutral swictch usually get connected or not?
02-02-2007, 10:19 AM
It's a good idea to have it hooked up. Nothing worse than reaching in from the outside to start the car and have it take off on you.
02-03-2007, 02:29 PM
Super Moderator
dblbbl could tell you that...poor garbage can.
Jamo
02-21-2007, 08:58 AM
UT
Cobra Make, Engine: FFR 3850, 95 Cobra 5.0 EFI, IRS, Pin Drive 15" real Magnesium Halibrands & Vintage Wheels, Billboards & Mickey Thompson S/T tires, Blue/Wht Stripes, Hoops, CSX Dash, Konis, VPMs, Torsen
T-5's have a neutral switch also.
I chose the clutch depression switch as the safety lockout.
Figured it was safer.
The reverse switch could be used for backup lights, if you wanted to mount those.
02-21-2007, 04:04 PM
NV
Cobra Make, Engine: 427 SC
Did you hook up a neutral safety switch? If so, how'd you do it?
02-21-2007, 04:28 PM
I haven't gotten around to it yet. The easiest I have found is to hook it up as an interupt between the starter selenoid and the ignition switch terminal 3 that engages the selenoid to start the car.
02-21-2007, 08:30 PM
CC Member / Sponsor
UT
Something to consider: if the clutch will not disengage (i.e. hydraulic problem) you are now stuck. Might be good to have a bypass switch so that in an emergency the car can be started in gear.
02-22-2007, 05:14 AM
BW
Cobra Make, Engine: Sorry "just" a 68 Shelby GT500
Install a neutral safety switch ?
Why would you want do that ?
You guys drive lightweight 400 HP+ cars - but canīt remember to take it out of gear before hitting the starter ??
hmmm...
68 GT 500
(Germany)
02-22-2007, 08:48 AM
hmmm...
Not everyone is as smart as you obviously are.
It's good for people who don't own the car and might be driving or working on it too.
02-23-2007, 05:44 AM
BW
My apologies - I did not mean to offend anyone!
Just have a hard time dealing with all the "necesary" unnecesary add-ons that modern cars are loaded with. Would not want to have any of it in my old cars...
68 GT 500
(Germany)
