Old 05-15-2007, 10:39 AM
Cobra Make, Engine: KMP 498
Default Doors?
Before I tear a bunch of stuff up, How do you remove the doors?
Old 05-15-2007, 11:09 AM
computerworks's Avatar
...4 bolts ...on the hinge.
What else are you planning to tackle?
(...just kidding)
Old 05-15-2007, 11:18 AM
Du! Thanks for the picture though.
I have a little cover under the hinge-looks like yours is already off. How do you take the pin out?
Old 05-15-2007, 11:24 AM
Originally Posted by big-boss
...looks like yours is already off.
on my car...everything is off.
I wouldn't disassemble the hinge pin. Are you talking about the plastic hinge cover being in the way? That should come off and then I'd unbolt the doors.
Old 05-15-2007, 01:06 PM
That is what i needed to know. I will leave the pin alone, final. Easy enough. Thanks again.
Are going to put on an oil cooler for the diff?
Old 05-15-2007, 01:07 PM
yes. I am.
Old 05-15-2007, 01:18 PM
RedCSX1's Avatar
Cobra Make, Engine: Shelby CSX 4766 (Vegas Built) with 482 Aluminum Pond motor
Default The best suggestion I can make......
Big Boss, Conact Tom at Tom's Motorsports and talk to him about your Rear end set up and oil coolers. He has tons of experience with these rear ends and you did say you wanted to built everything perfect on this Cobra. There are certain issues with these rear ends which I am sure Pat (Gasholes) would certainly be happy to share with you.
Cobra.http://tomsmotorsportsinc.com/Welcome.html
Morgan LeBlanc
Fresno CA
Old 05-30-2007, 05:55 AM
Banned
What issues are there with the rear end? BTW, which rear end are you talking about?
Old 05-30-2007, 05:59 AM
He is referring to the KMP diff...there was a problem with the diff slinging too much fluid out the vent hole in the cover. Baffelling or replacing the diff cover with a Jag unit or the one from Tom's seemed to be a cure.
Old 05-30-2007, 06:23 AM
Murphy's Avatar
Cobra Make, Engine: Kirkham #473 427 every option, Keithcraft aluminum FE 482 ci. Mass Flo FI. Tremec TKO 600.
Default Kirkham part 00064
Diff breather kit. You can see a picture on the Kirkham website. Click on the item number on their parts price list.
