Like Tree1Likes
Old 06-24-2007, 05:10 AM
Cobra Make, Engine: Kirkham 592
Default Are vents worth $1000?
The driver's is 500 and the passenegr the same. Are they needed. Who has them and who doesn't. Can they be added later?
Old 06-24-2007, 06:02 AM
Cobra Make, Engine: KMP 498
It does seem a little pricey, but very much worth it. I got the drivers side one only. I don't think they do much but general thinking is that the competition 427's had it that way. The Kirkhams prices seem high until you get the stuff after you see the quality and understand that you typically get more and the complete unit. You will be pleased with the value-I have been. Lots of times in this Cobra World you will buy the part then find how much more you still need to get or fabricate-Kirkhams typically give you the complete deal. Good luck with you journey.
Old 06-24-2007, 07:08 AM
double ugly's Avatar
I had a drivers side vent with blower on my Hi Tech. Useless in AZ.
double ugly
Old 06-24-2007, 01:37 PM
CJ428CJ's Avatar
Cobra Make, Engine: ERA #629, BBM Side Oiler Block, 482ci, Richmond 5 speed
My ERA has vents and I don't think they really do much. If I pull them on and off on a hot day I can't feel any difference. On a cold day, I can tell but only because it's freezing with them on and only slightly more comfortable with them off. I wouldn't pay $1k for them.
Chris
ERA 626 likes this.
Old 06-24-2007, 02:00 PM
Cobra Make, Engine: Cardiac, 428 FE
I'm curious why owners say that the footbox vents don't work? I'm researching a vent system from CobraEarl's FFR Accessories that has 12v fans in it now in hopes I can stop the roast. My footbox fronts are covered with ThermoCool foil insulation, my headers are ceramic coated, my footboxes are insulated on the inside; I'm still roasting.
What method gets the most cooling effect? Should I wrap the headers? How about the space between the inner fender and the body? Should that be sealed off? I assume that the hose in the CobraEarl's kit ($180) will have to be insulated to prevent heating air from the front vents as it passes through the engine compartment so, will that help the kit work? Anybody tried that kit?
Burning up in New Mexico, top and bottom.
Paul
Old 06-24-2007, 03:01 PM
ENTDOC's Avatar
you will have to insulate the hose. I have them on KMP266 and they help but 1K is pricey. I would add an inline fan
Old 06-25-2007, 07:37 AM
saltytri's Avatar
Cobra Make, Engine: KMP, Keith Craft
Or drive faster.
Old 06-25-2007, 07:39 AM
Maybe it's my imagination, but with both vents open, I smell less fumes from the side pipes.
Lew
I'm no expert.
Old 06-25-2007, 08:14 AM
richsd's Avatar
Cobra Make, Engine: 427 Cobra re-creation based on Kirkham aluminum body and chassis, Original 1965 Ford 427 Side Oiler and Ford Toploader transmission
I have them on KMP401. Yes they are worth it unless you want to melt your shoes. Put them in for sure.
Old 06-25-2007, 08:26 AM
I disconnected mine on my ERA. There like a 'blast furnace' of extreme temperature air (that melt your tennis shoes).
Old 06-25-2007, 09:54 AM
Igofastr's Avatar
Cobra Make, Engine: SPF GT40P-2265/393W, KMP318 (PROJECT!!!!!)/CSX478
I have one on the drivers side. Doesn't do a lot, but does help. And every little bit is needed in the summer.
Passengers haven't complained yet about the lack of one on their side...they're usually too busy with other things to notice, I think.
Ron R
"Dishwasher? I thought that was for cleaning parts!?"
Old 07-18-2007, 07:32 PM
Banned
School me on these blowers. I want to add them to my car. I noticed that I get a heat gun out of the vents until I drive 50 MPH for 5 minutes or more, then they cool down. With blowers, it should be "cool" all the time. . .
Where are they installed? Size? Brand name? Whatever you can tell would be great!
Old 07-18-2007, 07:52 PM
ENTDOC's Avatar
first , you have to insulate the ducting. Mine has cool air at any speed( well at least ambiant temp air) . A blower from Mcmaster Car or one of the boat supply companies is put in line in the ducting. Also look on EBAY, a lot of racing companies sell them for cooling brakes. The advantage of the blower is of course to blow high volume air when going slow, when you need it most.
Old 07-18-2007, 07:59 PM
Banned
I looked in Mcmaster, but what am I looking for. What I saw there all looked huge to fit inline. How do you insulate the pipe/hose? I assume just the area above the headers?
Old 07-18-2007, 08:16 PM
Dwight's Avatar
Default foot box air
I installed a 140 cfm 12 vdc vent fan with a 3" duct into the dash where it split into two 2" ducts. One for the driver side and one for the passenger side. I did this just before we drove to the LCS. I tried it a couple of time and just got hot air. My foot box does not get that hot but you know how it is. Coach Mike install one in his Cobra so I had to install one in mine. The jury is still out. Mine cost about $120.
As hot as it gets in Alabama I need an aircondition.
North Alabama, is has been 90-95 for weeks.
Dwight
Old 07-18-2007, 08:24 PM
Banned
Would this work:
http://www.grainger.com/Grainger/items/6KD70
installed right to the opening on the top of the footbox, inside? I can bolt it on, but I wonder if it would pull enough air. . .
Old 07-18-2007, 08:30 PM
Dwight's Avatar
Marine vent fans.
They have them in 3" and 4". The 4" is to big for what we want.
I've got a pic but can not find the invoice which has the model # and company that I bought it from. I try later.
Dwight
Old 07-18-2007, 08:49 PM
CHANMADD's Avatar
You can buy those from West Marine
http://www.westmarine.com/webapp/wcs...&storeId=10001
Old 07-18-2007, 09:29 PM
RedCSX1's Avatar
Can you guys that have them installed take a few pictures of fans mounted in place. Would like to keep the fan (blower) out of the engine bay.
Morgan LeBlanc
Fresno CA
Old 07-19-2007, 04:51 AM
Banned
Originally Posted by ST
What brand and model? Where did you get it? Does it make a big difference? How did you power it? Lots of questions. . .
