Like Tree2Likes
  #761 (permalink)
Old 07-29-2008, 08:44 AM
The most impressive part on that car is the rear wheelhouse, I'd love to see that being machined.
  #762 (permalink)
Old 07-29-2008, 09:55 AM
David Kirkham's Avatar
Original Shelby Owner
  #763 (permalink)
Old 07-29-2008, 11:08 AM
  #764 (permalink)
Old 07-29-2008, 11:34 AM
  #765 (permalink)
Old 07-29-2008, 12:13 PM
Too bad we didn't film that. The only way we could make that part is with a full 4 axis machine. That means all 4 axis of the machine are moving at once--X, Y, Z, and A. A is the rotary axis so the part is spinning while the machine is moving up, down, left and right, in and out. We had to move in all 4 axis to spin the part around the tool to get into the tight spots. We then had to "unwind" the part to get the tool back out.
I will look for some more pics of it being made for you.
  #766 (permalink)
Old 07-29-2008, 12:23 PM
The block we started with weighed 225 pounds. Each finished wheel house weighs about 2-3 pounds. (I'd have to check and see if I ever wrote it down). Here you can see Sandwich sawing the billet log in 1/2. The chunk of aluminum is pretty big--but it was the only way to turn the corner on the chassis to feed the rear suspension loads to the front of the car and finish off the tub.
  #767 (permalink)
Old 07-29-2008, 12:26 PM
Here one of the 1/2's of the block has been mounted into the mill. We welded extensions on to the block to get it far enough away from the rotary axis so the spindle didn't crash. We then cut the welded on areas off (along with any heat affected zone).
  #768 (permalink)
Old 07-29-2008, 12:28 PM
Here is a shot of the part almost finished.
  #769 (permalink)
Old 07-29-2008, 01:27 PM
  #770 (permalink)
Old 07-29-2008, 01:30 PM
Mr. Bruce,
That is all the pics of the rear wheel well I could find. If I find any more I will post them for you.
Thanks for watching!
  #771 (permalink)
Old 07-29-2008, 01:47 PM
As you can imagine, that makes a LOT of chips!
  #772 (permalink)
Old 07-29-2008, 01:54 PM
franklin's Avatar
Cobra Make, Engine: Polished KMP #488 / 427SC, 427 SO/482 by KC
Boy! They are cracking the whip on David to get this car done...
http://www.youtube.com/watch?v=GA03miHe3zk&NR=1
  #773 (permalink)
Old 07-29-2008, 02:59 PM
Hello Scotty,
Will it have a transparent aluminum window or is that just too much to ask?
  #774 (permalink)
Old 07-29-2008, 03:07 PM
  #775 (permalink)
Old 07-29-2008, 03:50 PM
  #776 (permalink)
Old 07-29-2008, 08:04 PM
  #777 (permalink)
Old 07-29-2008, 08:06 PM
Originally Posted by CobraMike View Post
Hello Scotty,
If I could figure out how to do it, I would!
  #778 (permalink)
Old 07-29-2008, 08:11 PM
I think I am the one cracking the whip here...mostly on ME.
  #779 (permalink)
Old 07-29-2008, 08:21 PM
  #780 (permalink)
Old 07-29-2008, 08:27 PM
Door sil tube (right under the door).
