December 2025
Old 07-22-2009, 04:57 PM
Superarnie's Avatar
Cobra Make, Engine: AC Superblower (part built)
Default Polishing advice please.
As some of you may know I am in the process of polishing stripes into my aluminum body. The remainder of the car will be brushed. I have the 'C' and 'S' grade Nuvite polish, but can't seem to get a perfect finish. I am using a wool bonnet on a rotary polisher at grade 'C', and another 'clean' wool bonnet to give a finish with the 'S' grade however I'm just not progressing at all and after hours of working in the same areas, still have tiny almost hair line type scratches which I can't remove to get a deep clear finish. Can anyone give any advice on this. I'm literally going in circles, in fact the area on the nose seems to becoming more hazy the more I polish it. I initially started with quite a lot of the polish with the grade 'C' but have used less and less each application- then went the same way with the 'S' but I still can't get a perfect finish. Please help.
Many thanks
Gary
Old 07-22-2009, 06:03 PM
Cobra Make, Engine: Kirkham #570 w Shelby FE
Wool bonnets only go so far, try diaper cloths and hand rub the final finish.
Old 07-22-2009, 10:20 PM
RodKnock's Avatar
I haven't tried it yet, but this is what I'll use when the time comes:
http://www.perfectpolish.com/Cloth.htm
http://www.irinfo.com/polish/html/polish.html
Old 07-23-2009, 05:44 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
Wool will actually do it's own "cutting", you might want to change up once you have it shinny to a finer cloth and do it by hand until it is mirror.
Old 07-23-2009, 07:07 AM
computerworks's Avatar
Some tips from Kirkham
http://www.kirkhammotorsports.com/ma...inishing.shtml
Old 07-24-2009, 02:26 PM
Superarnie's Avatar
Smile
Thanks very much guys for your advice. I'll give the terry towelling fleece type cloths a go. Wish me luck!!
regards
Gary
Old 07-24-2009, 03:34 PM
N2VENOM's Avatar
Cobra Make, Engine: Kirkham KMP500 LeMans- Roush 451 Shelby block; KMP Flip-top with cammer: KMP 289 Bronze under construction.
Hey Superarnie, Rodknock gave you a great resource. You might want to invest in a cyclo polisher for the final polish with the S grade. Remember, LESS COMPOUND IS BEST. Take your time and try to enjoy the process...
Display Modes
