November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 07-26-2009, 07:22 PM
Cobra Make, Engine: Kirkham 592
Default What are people using for exhaust bolts? I like the ss studs.......
But since I haven't installed my motor I'm not sure if they will fit. I have used them in other cars and the ARP ss studs are great if you have enough room for them. Anyway, any thoughts? I recently got my billet overflow tank. What a nice product!
Old 07-26-2009, 10:05 PM
Rick Parker's Avatar
I use the ARP stainless 12 PT bolts with drilled heads and safety wire them. It's a little extra effort but I haven't had any header gasket issues or loose bolts.
If I had the room for easy removal I too would use their Stainless studs but with a mechanical locking Jet nut in lieu of a split lock washer, I've seen the exhaust heat take the temper out of split washers and they end up flat and loose the ability to keep a nut on tight.
Rick
Old 07-27-2009, 12:30 AM
Xavier's Avatar
Cobra Make, Engine: Lonestar LS427, 408w, 48IDA Webers, TKO 600, 9" Currie 4-link 4.11 rear
ARP Stainless 12pt have worked the best for me, the heads are small enough to reach in there and re-tighten when necessary.
The high-heat flattens any SS washer.
Old 07-27-2009, 05:12 AM
The arp ss studs do not use a split washer. They use a flat washer and they do not loosen.
Old 07-27-2009, 05:36 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
Each hole has a story. And, each bolt, stud or cap screw has an equally interesting tale.
Old 07-27-2009, 08:28 AM
Cobra Make, Engine: KMP 498
Use bolts-Stay away from the studs. I just replaced No. 5 gasket sunday. It took 5min. I also use the the Mr. Gasket gaskets but cut them into individual ones. That is the first one I ever had to redo. I do not know why it went out. Good luck.
Sanded Aluminum Finish? Because I Can!
Old 07-27-2009, 01:25 PM
Tom Wells's Avatar
ng8264723,
Not sure I'd use SS in aluminum heads. There's this galvanic corrosion that occurs that make them less than wonderful to deal with long term....
After some learning experiences, I now use the Stage 8 Locking Fasteners. They're a bit of a pain to install the first time, but have cured the leaking header backfire blues once and for all.
Whatever you do, don't even think about using the split-lock bolts (the ones with the tiny allen screw in the center to lock them); they ate the threads in my aluminum heads! I did notice they looked like taps anyway... Then to add insult, one of the little allen screws fell out after about a month! 'nuf said.
Try the Stage 8s, you may like them.
Tom
Old 07-27-2009, 03:39 PM
MFE III's Avatar
Cobra Make, Engine: Hurricane Motorsports, 427w
I used SS studs on my aluminum AFR heads (1) so I wouldn't have the wear and tear on the threads from taking my headers on and off, and (2) to eliminate the chance of cross-threading the heads. Due to a couple of tight radius bends in my headers coming out of the flange, I had to shorten a couple of the studs, but very pleased with the setup.
Matt
Hurricane Motorsports #1053; 427w
Old 07-27-2009, 05:08 PM
Cobra Make, Engine: Kirkham #570 w Shelby FE
Stage 8, unless your a glutton for punishment and like safety wiring (or blown gaskets).
Anti-sieze on anything going into aluminum (unless they're nickel plated bolts).
Old 07-27-2009, 06:30 PM
Cobra Make, Engine: FFR Challenge Car, RDI aluminum 427w
I user 3/8-16 black oxide carbon steel allen set screws at 1 1/4" long with AN series washers (not lock washers) and stainless nuts. All from McMaster-Carr www.mcmaster.com for about $27 and I then have 84 extra nuts and washers. I also use the 3" bolt spacing which allows a lot of room around the tube. This may not work if you use the 2" spacing.
I put anti-seize on the set screws and back them off about 1/8 turn from bottom. I also run copper header gaskets that don't compress and blow out.
Once tightened after the 2nd or 3rd heat cycle they stay tight.
Jim
