Old 08-19-2009, 01:22 PM
Cobra Make, Engine: KMP-216S Kirkham Street '66 428 PI
Default Sunburst wheels on a Kirkham
Hey Gang,
I've got a set of orig sunburst wheels. (Purported to be off CSX 3231)
I want to fit them on my street 427 but the rub on the outside of the calipers.
Anybody have any ideas or experience with this?
Kurt
Old 08-19-2009, 01:38 PM
cobrajeff's Avatar
You have two choices - do a little grinding with a die grinder on the calipers, or have a good machine shop cut a clearance groove in the back of the rim on a lathe. You want to check the thickness of the rim in that area before doing any machining.
I have had to rework wheels and calipers in this manner several times (on different cars) over the years.
regards,
Jeff
CobraJeff
ERA P 202
Old 08-19-2009, 02:45 PM
CC Member / Sponsor
Another option might be a spacer. The rims are tapered on the inside...
Just for a check, try putting washers around the drive pins and see if that gives you enough clearance. If that works there are a couple of more permanent options available with out having to grind.
Cubic Performance
HiTech Legends
https:HiTechLegends.com
Evolve Lubricants
https://evolvelube.com/
Old 08-19-2009, 04:31 PM
Thanks Tom and Jeff. I'll try the spacers first and consider the grinding deal the last resort.
Kurt
Old 08-19-2009, 06:40 PM
RON N BKFLD's Avatar
Cobra Make, Engine: KMP241 427 S/C 482 Shelby
Tom,,,,Are you making spacers? I still need 2 5/16 or 3/8 spacers to make my FIA Trigos work.............Ron
RON N BKFLD
Old 08-19-2009, 06:57 PM
Original Shelby Owner
Cobra Make, Engine: 31XX Car
Default Sunbursts
Please do not grind/machine the wheels. There are only so many original wheels and if modified/damaged it would be a shame for the guy who may end up with them down the road and want to put them back on an original car. If the calipers are repro, it would be the lesser of the evils to grind them......or try spacers like Tom Kirkham suggests.
Old 08-19-2009, 08:38 PM
CC Member / Sponsor
I am not a big fan of spacers. It is important that a spacers does not act like a thrust washer-- allowing the rim to turn relative to the hub. This is even more important when the wheel is attached with a mono-nut. Ron 2 5/16 inches is a lot. I would be very nervous making a spacer that thick let alone driving on it.
Cubic Performance
HiTech Legends
Evolve Lubricants
Old 08-19-2009, 08:54 PM
427sharpe's Avatar
Tom,
From his post I think he meant two 5/16" spacers, not a 37/16".
Old 08-19-2009, 11:29 PM
CC Member / Sponsor
Originally Posted by 427sharpe View Post
Tom,
Thanks!!! I feel a lot better now.
Cubic Performance
HiTech Legends
Evolve Lubricants
Old 08-22-2009, 01:20 AM
PANAVIA's Avatar
Wonder why nobody makes repro sunbursts....
Old 08-22-2009, 05:40 AM
mickmate's Avatar
These are cast from originals http://www.clubcobra.com/classifieds...uct=1777&cat=4
mickmate
http://www.actoncustom.com/
Old 08-22-2009, 08:41 AM
427sharpe,,,,thanks, you are correct, two 5/16 spacers for front FIA Trigos...Ron
RON N BKFLD
Old 08-22-2009, 12:45 PM
Hi Kurt,
I make billet aluminum wheel spacers in 1/8", 1/4" & 3/8" thick and are made with either 5 x 4.5" & 5 x 4.75" bolt pattern.
NOTE: WHEEL STUDS MUST BE LONG ENOUGH TO ENGAGE THE LUG NUT COMPLETELY.......
Forte's Parts Connection
40 Pearl St
Framingham, Ma. 01702
fortesparts.com
508 875 0016
In 1993 Mike made the first conversion of a Ford Tremec to GM 5-speed. It bolts to stock bellhousings w/out an adapter. The FE Tremec, the Mustang adjustable quadrant are originals from Mike.
One of 12 Tremec Elite Distributors worldwide for: T-5, T-56 Magnum & TKO-500 & TKO-600 ,Midshifter, Frt shifter, offset Vette shifter.
Est: 1981 selling performance parts to build your dream car...
Old 08-22-2009, 01:36 PM
mickmate's Avatar
Hey Mike I think he'll be needing the six pin which I can make.
mickmate
Old 08-22-2009, 04:25 PM
Where original wheels alum. or magneseium and are there any reproductions or recasts available?
Old 08-22-2009, 07:52 PM
mickmate's Avatar
I believe they were aluminum but these are magnesium http://www.clubcobra.com/classifieds...uct=1777&cat=4
mickmate
