Go Back   Club Cobra > Club Forums > Las Vegas Cobra Club
Old 01-17-2008, 08:45 PM
bigrob's Avatar
Cobra Make, Engine: BDR # 126/ K. Craft 306 CID/375 HP- 306 RWHP
Default Oil cooler
My car does not have an oil cooler & I want one. Any suggestions?
Thanks again!!
Rob
" Listen to that music! "
'65 BDR #126
'84 Porsche 928S
'01 Corvette C5 coupe
'99 Ford Explorer Limited
Old 01-18-2008, 11:01 AM
Curt C.'s Avatar
Hi Rob. If you post in the BDR forum you will get better response. This is the las vegas club forum. We post here about meetings and such; not so much about tech issues.
Old 01-18-2008, 12:19 PM
CHANMADD's Avatar
Try this ,I have used these for quite a long time and have had no problems at all and it does seem to work great and it looks the part once mounted. It even comes polished.!!
http://store.summitracing.com/partde...5&autoview=sku
Old 01-18-2008, 12:42 PM
Cobra Make, Engine: FFR - 427w
Rob, are you gonna run your car at the track? If not, you may not need one. But if you want one I'd check with Backdraft and see if they have one made to fit your car.
Old 01-18-2008, 03:15 PM
ST's Avatar
ST ST is offline
Cobra Make, Engine: Kirkham#182/Shelby 496c.i.
Here's the one Backdraft sells for their cars.
http://www.backdraftparts.com/shopexd.asp?id=88
"You can NEVER teach a pig to sing! You'd just be wasting your time and annoying the pig!"
Old 01-18-2008, 08:03 PM
bigrob's Avatar
I have spaced the fact that this is the LV club forum & not really a tech Q forum, sorry bout that!
I do appreciate the info listed guys!! thanks! I am not gonna track the car, but would feel a little better with the cooler.
Rob
'65 BDR #126
'84 Porsche 928S
Old 01-18-2008, 08:28 PM
lineslinger's Avatar
Big...Rob...,
What is your engine size, big block or small, street or track, soft (street) or hard (track) driving, what type of oil filtration system do you have now, what type of oil does your powerplant require, how do the Vegas temps. influence the temp.range of your engne, what is the long range intent of your driving?
If a cooler would make you feel better install one with a thermostat..or.. install a fake one...........many do.
Old 01-19-2008, 10:52 AM
Curt C.'s Avatar
Rob, I live in Vegas. If I did not tack the car, I would not run the cooler for the fact that I cannot generate enough heat when the weather is cold. I actually tape the cooler up when aluminum tape when not on the track. If you like the looks of one, mount it but do not connect it unless your temps are truly running too hot.
Old 01-19-2008, 11:12 AM
MaSnaka's Avatar
The oil cooler is cool, but it does suck some oil pressure out of your system with the extra plumbing. For the street not necessary. You do want the oil to temp past boiling to burn off any moisture that gets in there. High capacity system with a cooler make this pretty hard to do unless your driving it hard at sustained rpms. As sugested above the T-Stat would solve that issue...again more plumbing. You can always hook it up and try it. If it helps great, if not you can always disconnect it and cap it off and keep it for looks.
Old 01-19-2008, 02:13 PM
Rob, Curt is correct. On the street my biggest problem is getting the oil up to operating temps. I'm considering one of these to help: http://64.202.180.37/files/laminova.pdf
Should warm up the oil faster and keep the temps lower when under heavy loads or sustained high RPM's as in racing.
Otherwise I'd go with the Backdraft setup (with shroud) and install a oil thermostat.
Old 01-19-2008, 07:56 PM
bigrob's Avatar
This has nothing to do with looks! I just want to make sure the oil does not get crazy hot, mainly in the summer heat! I will definately not be tracking or racing the car.........except, of course, on the street sometimes! Gotta have some fun! If you guys think I will be OK with out it, that's good enough for me.
Once again, Grazie!!
Rob
'65 BDR #126
'84 Porsche 928S
Old 01-19-2008, 11:10 PM
CHANMADD's Avatar
Hey Rob, I know the cooler I suggested is not $300-00 odd , but it does work well. Difficult to beat for the money and not too much money to try it out. They sell an adaptor as well as hose. I used hose that does not even use clamps at the cooler fittings. Really clean install and no leaks! I will add pics tomorrow am.
Old 01-20-2008, 08:40 AM
Curt C.'s Avatar
Doug,
Mocal makes some nice pieces don't they? I too have looked at that unit. Plumbing would be difficult in my application but not impossible. Let me know if you install one; I would really like to see it.
Old 01-20-2008, 09:06 AM
Rob, I have a cooler on my car. In Texas the oil wouldn't get warm enough so I added a T-stat...still didn't get warm enough for my liking. In Vegas on the hottest day (maybe 115 or so) in stop and go traffic it only got to 230 or so indicated with the coolant temp about 205-210. It basically follows the cooling system temp, so when I would get back on the open road the coolant temp would drop back to thermostat temp (180-185) and the oil temp would drop to about 200-210. On these very hot days, if I avoided stop and go traffic, the oil would have trouble getting above 200 degrees, so still not hot enough for my liking, even with the MoCal T-stat. I'm thinking about changing to a different t-stat to get the oil temp higher, but then would that affect the coolant temp?
FWIW, I don't track my car. I think the oil cooler looks cool, but is overkill for street machines, and not necessary. Maybe I'll just cap mine off...
Ken
Old 01-20-2008, 07:27 PM
bigrob's Avatar
I appreciate the info Ken! Thanks! I have a cooling fan override switch, & will will utilize it alot, in the summer, in stop & go if need be!
Thanks again!
Rob
'65 BDR #126
'84 Porsche 928S
Old 01-20-2008, 07:36 PM
jwoodard's Avatar
Thumbs up
mr0077,
If you're thinking about changing thermostats, consider the Canton. It is set to open at 212 degrees. I installed one on my SPF for the same reasons you did. Once the thermostat opens, the oil stays at 100C or a little higher unless I'm on it real hard for a continued period if time. The coolant temp stays around 90- 95C. Check my gallery for some photos of the install.
Jim Woodard
