Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Lone Star Classics---Speak with Dennis & Steve
Old 08-16-2002, 11:38 AM
Unhappy Front end question
Hello everybody,
I like to get some feedback on where some of the Cobra front end settings are.
Please send me the settings for Toe, Caster and Camber also indicating the Tire size and make of the car.
That will help me to find the best setting for my car.
Thank you all
Thomas K.
Old 04-28-2004, 12:19 PM
BPWilliams's Avatar
Cobra Make, Engine: none
Default What...?
Don't tell me knowbody know what thier set up is???? Mine is way out of wack! I am running 285's up front and I set the whole thing up on zero! it is not working to well, at the track I am being left in the dust on the turns.............SO does anybody run thier Lone Star on the track? If so what is your car set up to?? Here is what I think it should be:
Toe = zero to -.5
Caster = 5 deg
Camber = 2 deg
Any thoughts?
L8R,
Brian
There is No Replacement for Displacement.
U.S.A. All the Way!
Old 04-28-2004, 03:16 PM
DAVID GAGNARD's Avatar
While my car is not a Cobra,but a 3100 lb. 65 Mustang I will post my frontend settings.This setting does work extremely well on the road course and drives very well on the highway.........
Caster---2.5 degrees positive-both front wheels
Camber---.5 degree negative--both front tires
1/16 of an inch toe-in........
Tire wear is not bad on the street at all...... I have tried other settings and this one seems to be a good compromise for the road course and street.........
Some of the Vintage Mustangs that are strictly track only race cars run the following settings;
caster---4.0 degress positive--both front wheels
camber 1.5 degress negative---both front tires
0 or no toe-in at all
DAVID GAGNARD
Old 04-28-2004, 03:40 PM
mbishop's Avatar
Cobra Make, Engine: Lone Star Classic LS427 (Under construction)
Send a message via Skype™ to mbishop
Brian,
I have a file Brian at Lone Star sent me that has the alignment specs. Send me your email and I will forward it to you.
Mark
Texas Tuff
Old 06-04-2004, 09:32 AM
Cobra Make, Engine: LoneStar, Stoked 351W
Default LoneStar Recomendation
Here is what LoneStar sent me:
Toe total (1/8)" on both sides, + or - (3/32) PREFER 1/8
Camber - 1 (1/2), + or - (1/2) deg on both sides
Caster + 4 (1/2), + or - 1 deg PREFER 5 Deg
CaliforniaCobra
