| S |
1 |
| 3 |
5 |
8 |
| 10 |
12 |
15 |
| 17 |
19 |
22 |
| 24 |
26 |
29 |
30 |
| 31 |
10-29-2007, 03:20 PM
Tx
Cobra Make, Engine: 2002 Lone Star Classics LS427, 428 CJ engine stroked to 464, 580hp/590tq at flywheel
Wheel options - Lone Star
Man - everyone must be mad at me. Just cause I been Vipering it for a while. I had 48 hits and no responces on the general discussion forum. Here is what I had posted - at least tell me if my thinking on the backspacing is correct. I need to get some street wheels so I can drive my Cobra - road race slicks suck on the street!
"I run a set of Boyd Coddington's on my car - 17 x 9.5 - 4.75 BS and 17 x 8 - 4.25BS. I run 315s on rear and I think 245 on front. Anyway the 9.5 inch have always been a little narrow for the 315s. I have mounted a set of slicks on the BC wheels and now use them for nothing but the track. I wanted to order a set of street wheels in 10.5 " and wanted the Vintage Wheels. I called Bob and he cannot do them without the wheels being about 1 inch wider to the outside than what I have now. My 315s are already out towards the outside edge of the fender so I don't want that.
Any suggestions on other brands? I really don't want to have to narrow the rearend.
Also, am I thinging about this correctly - if I go to a 10.5" and want to keep the outside edge of tire/wheel where it is now I need a 5.75 backspace?"
10-29-2007, 04:02 PM
CA
Jim Woodard
10-29-2007, 07:28 PM
Tx
Jim - I started off thinking the same as you about backspacing, but after thinking about it the tire is what I want to keep in the same position, so basically the center line of the wheel needs to remain the same. Since the tires has a 12 inch tread the wheel lip will be 1/2 inch wider on both sides but the tires will actually remain in the same locatiopn I thinK. The wider wheel will spread the tire out but not change is location of the wheel in the wheel well. That would make for a desired backspacing of 1/2 the wheel width or 5.25"? The original BS is 1/2 the wheel width, or 4.75 on a 9.5" wheel.
What do you think? Anyone else comment?
10-29-2007, 07:38 PM
6th Generation Texan
TX
If the Boyd you have is 9.5 and you are going to 10.5,you are 100% correct. 5.75" backspace.
I have the Smoothie II and they are 10".Which Boyds do you have ?
BTW - You have the room to go to 6" easily.
10-29-2007, 08:38 PM
Tx
They are Smoothies - I think series I. Yea, I agree, plenty of room on the inside. Bob with Vintage installed some 10.5 on some guys LSC in New York so he is calling them to see about their fit. I really like the look of the Vintage Wheels.
11-09-2007, 07:28 AM
The rear Smoothies are 10"..
Too many toys?? never!
