Old 11-02-2009, 10:57 AM
Default Low Side A/C Suction Fitting -- 2003 Camry V6 Engine
I will be charging someone's V6 Toyota Camry this evening. I have my manifold gauges and 134 canister, but have never looked under the hood. Does anyone know off the top of their head where the suction fitting is on that particular car?
Old 11-02-2009, 11:36 AM
Here you go, helps to have the VIN:
http://www.toyodiy.com/parts/
I also have the entire worldwide Toyota Microcat parts and service system at my disposal at home...email me tonight if you need help or scans.
Old 11-02-2009, 11:49 AM
Thanks. Although some might say that if I can't find the low side fitting then I have no business charging the system to begin with... and they'd be right.
Old 11-02-2009, 12:25 PM
Well, if its any consolation, there should be two gray plastic screw-on caps on the lines at the compressor, one marked with "L"and one with "H."
Got it?
Old 11-02-2009, 12:26 PM
Originally Posted by elmariachi View Post
Well, if its any consolation, there should be two gray plastic caps on the lines at the compressor, one marked with "L"and one with "H."
Got it?
Well, I guess the "L" is for liquid, so I'll just hook it up to the other one then.
Old 11-02-2009, 12:44 PM
Well its a hydraulic lifter engine, so you aren't even supposed to me messing with it in the first place.
Old 11-02-2009, 12:46 PM
I probably won't even be able to get the hood open.
Old 11-02-2009, 12:49 PM
Still feeling a bit beaten down over the whole "real" versus "not real" thing, aren't you?
Old 11-02-2009, 12:50 PM
I could of won that, too....
Old 11-02-2009, 12:52 PM
Baahaahaaaa. You caved too quick. Go drink a teaspoon of Brad Penn and you'll feel better, works for me every time.
Old 11-02-2009, 12:53 PM
That's not a bad idea.
Old 11-02-2009, 01:11 PM
El,
Any new updates on your vibration problem?
Old 11-02-2009, 01:20 PM
El,
Nope. I am going to let Mr. Side Oiler use his muscles to solve it for me.
Old 11-02-2009, 05:25 PM
Senile Club Cobra Member
The answer is over at ClubCamry.com!!!
rick@autoventureusa.net
Old 11-02-2009, 05:27 PM
Well, the correct answer is "on the passenger side, close up against the firewall, about a foot down from the top of the engine."
