11-10-2010, 10:56 AM
Cobra Make, Engine: CSX2498 has been in our family garage since '68....Scratch built aluminum bodied 427SC Cobra, 427FE, CSX3000 chassis specs, 95% finished, only needs paint.
computer problem
Hello, I have no audio on my computer, the box says that my speakers are unplugged. I have checked the plug and installed new speakers and I still get the same message. I tried to reboot the system and it is still without audio.
any help?
thanks, karl
11-10-2010, 11:11 AM
Karl,
You may need to download a new driver for the speakers and or external speakers.
Go to your computers manufacturers website and see if have a place where you can check for updated drivers.
If everything is plugged in on both ends and the external speakers are turned on, then the next thing to check would be the drivers.
11-10-2010, 12:40 PM
thanks for your reply, I did that step and the box says taht my speakers are not plugged in. Is there a possibliity that something came apart on the inside of the computer tower?
thanks again, karl @ GT
11-10-2010, 04:59 PM
If so you would have had to have dropped it or bumped it around pretty good.
Is there a reset button on the back of the main speaker?
Also, some of the speakers now have seperate woofers. If you dont have the woofer plugged in the little speakers will not work.
For example, the woofer would plug into the back of the tower and then the little satelite speakers would plug into the woofer.
That is how they work on our Desk top PC.
11-11-2010, 10:32 AM
Abnormal CC Member
Look under control panel for Sound and Audio Devices. There should be something there to control volume and there should also be something that can MUTE your speakers as well.
Make sure that MUTE is not chosen and that the volume is up.
11-11-2010, 10:44 AM
thanks for the responses, I have tried all of that stuff and still no audio. I have a friend coming over on sat to take a look.
I had a peek inside the tower and there is no seperate sound card that I can see, so I need help.
thanks again, karl
11-11-2010, 12:44 PM
Ca.
After my last virus bombardment, my computer says that I have speakers plugged in but they will not work (when plugged in from the back). I plugged them into the headphone jack in the front and they work fine from there.
You can try that for a bandaid until it gets fixed.
Terry
11-11-2010, 02:03 PM
thanks for the suggestion, I tried the different plug in and it did not work.
thanks again, karl
11-11-2010, 04:03 PM
this was on the microsoft site.....
this is a copy and paste of what another user of vista did....
Quote.........
This fixed my problem for sound not coming through speakers in windows vista, Go to start, Click control panel, then choose hardware and sound,Then choose sound,Under playback there should be a green check mark on the Realtek High Definition Audio,and should say working. Click once on the speaker picture,Now choose the option configure in the bottom left of window pane,then from the options pick quadraphonic,then click next and make sure that the options front left and right and surround speakers are checked,then click next and finish.Hoped this helped someone
end quote.......
and this is a link to the updated driver ....
http://www.realtek.com.tw/downloads/...&GetDown=false
hope it helps
fred
Fred B
