Old 05-01-2008, 08:11 AM
thorconstr's Avatar
Cobra Make, Engine: ERA 427" 351W
Default Pumping gasoline
I think you will find this of interest!
> ?TIPS ON PUMPING ?GAS
> I don't know what you guys are paying for gasoline.... but here in
> California we are also paying higher, up to $3.96 per gallon. But my
> line of work is in petroleum for about 31 years now, so here are
> some tricks to get more of your money's worth for every gallon..
> Here at the Kinder Morgan Pipeline where I work in San Jo se, CA we
> deliver about 4 million ga llons in a 24-hour period thru the pipeline.
> One day is diesel the next day is ?jet fuel, and gasoline, regular
> and premium grades. We have 34-storage tanks here with a total
> capacity of 16,800,000 gallons.
> Only buy or fill up your c ar or truck in the early morning when the
> ground temperature is still cold. Reme mber that all service
> stations have their storage tanks buried below ground. The colder
> the ground the more dense the gasoline, when it gets warmer gasoline
> expands, so buying in the afternoon or in the evening....your gallon
> is not exactly a gallon. In the petroleum business, the specific
> gravity and the temperature of the gasoline, diesel and jet fuel,
> ethanol and other petroleum products plays an important role.
> A 1-degree rise in temperature is a big deal for this business. But
> the service stations do not have temperature compensation at the pumps.
> When you're filling up do not squeeze the trigger of the nozzle to a
> fast mode. If you look you will see that the trigger has three
> (3)stages: low, middle, and ?high. In slow mode you should be pu
> mping on low speed, thereby minimizing the vapors that are created
> while you are pumping. All hoses at the p ump have a vapor return. If
> you are pumping on the fast rate, some other liquid that goes to
> your tank becomes vapor. Those vapors are ?being sucked up and back
> into the underground storage tank so you're getting less worth for
> your money.
> One of the most important tips is to fill up when your gas tank is
> HALF FULL or HALF EMPTY. The reason for this is, the more gas
> you have in your tank the less air occupying its empty space.
> Gasoline evaporates faster than you can imagine. Gasoline storage tanks
> have an internal floating roof. This roof serves as zero clearance
> between the gas and the atmosphere, so it minimizes the evaporation.
> Unlike service stations, here where I work, every truck that we load
> is temperature compensated so that every gallon is actually the
> exact amount.
> Another reminder, if there is a gasoline truck pumping into the
> storag e tanks when you stop to buy gas, DO NOT fill up--most likely
> the gasoline is being stirred up as the gas is being ?delivered, and
> you might pick up some of the dirt that normally settles ?on the
> bottom. Hope this will help you get the most value for your ?money.
> DO SHARE THESE TIPS WITH OTHERS!
> WHERE TO BUY USA GAS, THIS IS VERY IMPORTANT TO KNOW. READ ON
> Gas rationing in the 80's worked even though we grumbled about it.
> It might even be good for us! The Saudis are boycotting American
> goods. We should return the favor.
> An interesting thought is to boycott their GAS.
> Every time you fill up the car, you can avoid putting more money
> into the coffers of Saudi Arabia. Just buy from gas companies that
> don't import their oil from the Saudis.
> Nothing is more frustrating than the feeling that every time I fill-up
> the tank, I am sending my money to people who are trying to kill me, my
> family, and my friends.
> I thought it might be interesting for you to know which oil
> companies are the best to buy gas from and which major companies
> import Middle Eastern oil.
> These companies import Middle Eastern oil:
> Shell........................... ?205,742,000 barrels
> Chevron/Texaco......... ?144,332,000 barrels
> Exxon/Mobil............... ?130,082,000 barrels
> Marathon/Speedway... ?117,740,000 barrels
> Amoco............................62,231,000 ?barrels
> Citgo gas is from South America - a Dictator who hates Americans. If you
> do the math at $30/barrel, these imports amount to over $18 BILLION!
> (oil is now $90 - $100 a barrel
> Here are some large companies that do not import Middle Eastern
> oil:
> < BR>> Sunoco..................0 barrels
> Conoco..................0 barrels
> Sinclair..................0 barrels
> BP/Phillips.............0 barrels
> Hess.............. ........0 barrels
> ARC0.....................0 barrels
> If you go to Sunoco.com <http://sunoco.com/%3E; , you will get a
> list of the station locations near you.
> All of this information is available from the Department of Energy and
> each is ?required to state where they get their oil and how much
> they are importing.
> But to have an impact, we need to reach literally millions of gas
> buyers. It's really simple to do.
> Now, don't wimp out at this point.... keep reading an d I'll explain
> how simple it is to reach millions of people!!
> I'm sending this note to abo ut thirty people. If each of you send it to
> at least ten more (30 x 10 = 300)...and those 300 send it to at
> least ten more (300 x 10 = ?3,000) .. and so on, by the time the
> message reaches the sixth ?generation of people, we will have
> reached over THREE MILLION consumers ?!!!! !!! If those three
> million get excited and pass this on to ten friends each, then 30
> million people will have been contacted!
> If it goes one level further, you guessed it ..... THREE HUND RED
> MILLION PEOPLE!!! ?
> Again, all you have to do is send this to 10 people. How long would all
> that take?
Al W.
Old 05-01-2008, 08:16 AM
Ron61's Avatar
Post
Al,
Not to detract from your post, but I believe that was posted once before some time back. I forget which forum it was in, but maybe a search will locate it.
Edit: Here it is. Another gas thread... but a bit different, interesting
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
Old 05-01-2008, 04:09 PM
Bob In Ct's Avatar
And if you jump up just before the plane crashes you wont get hurt.
Old 05-02-2008, 04:36 AM
Hi Bob!
I heard that the "jumping up" technique can also be applied to elevators? LOL
Also, jumping out of race cars just before impact can be helpful. Back in the day a driver named Masten Gregory used to do this. My parents were at either Goodwood or Silverstone and he did this right in front of the bleachers they were sitting in. Just before the car wrecked, he jumped out! landed in the bleachers and dusted himself off LOL
