01-05-2009, 03:44 PM
Ga.
unbelieveable
Sent: Monday, January 05, 2009 3:43 PM
Sent: Monday, January 05, 2009 2:24 PM
Subject: WHY FLY CHINA AIRLINES?
Thought you would be interested in this minor maintenance problem.
Consider this before catching that cheap flight on China Air.
For anyone who is not familiar with a jet engine, a jet fan blade should be PERFECTLY smooth.
A pilot for a Chinese carrier requested permission and landed at FRA (Frankfurt,Germany) for an unscheduled refueling stop. The reason became soon apparent to the ground crew: The Number 3 engine had been shutdown previously because of excessive vibration, and because it didn't look too good. It had apparently been no problem for the tough guys on the ground back in China: as they took some sturdy straps and wrapped them around two of the fan blades and the structures behind, thus stopping any unwanted wind-milling (engine spinning by itself due to airflow passing thru the blades during flight) and associated uncomfortable vibration caused by the sub optimal fan.
Note that the straps are seat-belts ....how resourceful! After making the "repairs", off they went into the wild blue yonder with another revenue-making flight on only three engines! With the increased fuel consumption, they got a bit low on fuel, and just set it down at the closest airport (FRA) for a quick refill.
That's when the problems started: The Germans, who are kind of picky about this stuff, inspected the malfunctioning engine and immediately grounded the aircraft. (Besides the seat-belts, notice the appalling condition of the fan blades.) The airline operator had to send a chunk of money to get the first engine replaced (took about 10 days). The repair contractor decided to do some impromptu inspection work on the other engines, none of which looked all that great either. The result: a total of 3 engines were eventually changed on this plane before it was permitted to fly again.
And we were worried about toys with lead paint!
No virus found in this incoming message.
Checked by AVG - http://www.avg.com
Version: 8.0.176 / Virus Database: 270.10.2/1873 - Release Date: 1/3/2009 2:14 PM
IRS Circular 230 disclosure: To ensure compliance with requirements imposed by the Internal Revenue Service, we inform you that any U.S. tax advice contained in this communication (including any attachments) is not intended or written to be used, and cannot be used, for the purpose of (i) avoiding penalties under the Internal Revenue Code, or (ii) promoting, marketing or recommending to another party any transaction(s) or tax-related matter(s) addressed herein. This communication may not be forwarded (other than within the recipient to which it has been sent) without our express written consent.
Perry
01-05-2009, 03:52 PM
Ga.
Perry
01-05-2009, 06:47 PM
Super Moderator
Perry...next time you're going to cut and paste from an e-mail, try to do better than a Chinese airline mechanic. Delete the unnecessary stuff and close up all the white space. Thanks.
That is indeed scary.
Jamo
01-05-2009, 07:23 PM
For anyone who is not familiar with a jet engine, a jet fan blade should be PERFECTLY smooth...
...The reason became soon apparent to the ground crew: The Number 3 engine had been shutdown previously because of excessive vibration, and because it didn't look too good. It had apparently been no problem for the tough guys on the ground back in China: as they took some sturdy straps and wrapped them around two of the fan blades and the structures behind, thus stopping any unwanted wind-milling (engine spinning by itself due to airflow passing thru the blades during flight) and associated uncomfortable vibration caused by the sub optimal fan.
Note that the straps are seat-belts ....how resourceful! After making the "repairs", off they went into the wild blue yonder with another revenue-making flight on only three engines!.......
Geez Perry,
You'd think they coulda ground those rock dents outta the blades and re-balanced them by eye ...like I do my lawnmower blades.
If I do fly anywhere in this economy, I'm going to see if I can inspect the plane myself first.
If I see an engine like this one, then I'll only sit on the good side of the aisle.
Wes
01-05-2009, 08:07 PM
Ca.
I had to send that to my son. He is a jet mechanic in the Navy.
Terry
01-05-2009, 08:49 PM
AL
This story has been circulating for several years and is likely not entirely true.
http://www.snopes.com/photos/airplane/airchina.asp
Tommy
Previously owned EM Cobra
01-05-2009, 10:11 PM
It would not surprise me if it were true. I spent 6 months in China, a lot of it solo. I flew on a plane with chickens in the overhead and a goat tied to a hitching post in the rear holding area were we boarded from (we boarded up a ramp from the back of the plane - it was some Russain model). This was a 6 hour flight from Beijing to Urumqui with no first class and seats designed for tiny Chinese butts. There were no seat assignments - you just fought your way to whatever seat you wanted.
They also ran a modem cable in through a building window. During monsoon season! Water ended up pouring in through the window, and the main power feeds for the systems we were building were laid out on the floor.
Good times...
If you can't stay on the road, get off it!!
01-06-2009, 05:22 AM
Ga.
Jamo, accidently reply before confirming image would appear!. Sorry.
Perry
01-07-2009, 07:16 PM
MA
Cobra Make, Engine: Butler with home-rebuilt 393 Cleveland stroker(Ya---ikes!)
I've heard that!
(That some Russian models look like goats!)
Hoy!
Freddie
01-07-2009, 08:47 PM
Ca.
This is the answer that I received from my son.
Wow, what the f--- were they thinking.
Terry
01-08-2009, 11:41 AM
Member of the north
Cobra Make, Engine: A Cobra
There is no telling what someone will do when properly motivated.
Where the heck is that poster???
01-09-2009, 12:01 PM
MA
THIS, from the same people.....
...who still own more water buffalo than cars and raise their rice in flooded field laced with yoomin poop?
Yah, they own all our debt-----thanks to short-sighted "business" dorks. Yet, they want to steal our mil-tech, scramble our compootahz, shove our navy aside and invade Taiwan. Good luck. (O'course making our military ops utterly and totally dependent on compootahz is lunacy)*!
Chow-duh
*o'course #2, you must temper my rants with the fact that I was a Weaps Occifer on a pre-missile, all gun DD---talk aboot a troglodyte!
Freddie
01-09-2009, 02:07 PM
Chow-duh
I would guess that it is harder to jam the 'guidance system' of a 16 inch shell than that of a missile. Still, how accurate are you going to be if your gun director gets taken out? And, Gee Whiz (  ), how are you going to shoot down inbound missiles without compootahz? Gonna pull that Gatling gun out on it's horse drawn gun carriage and fire away? Or are you going to use a trusty .50cal mount to take out an inbound 3 square feet small moving at 4000mph?
Steve
01-09-2009, 07:58 PM
MA
Uhhhh......
.......last time I checked WE (not the Chinese) were the last to use 16" rifles and, although I served in Crypto.....I'm not exactly sure whatcherpoint is.....
Ar-r-ar-ar-ooooogle!
Freddie
01-12-2009, 08:15 AM
Freddie,
Seemed perfectly understandable to me (provided you know your history and I know you do).
Ever since the Nagato got nuked we are the only ones to have 16 inch rifles. The Chinese would use Silkworms, and it is possible that we might be able to jam the guidance systems, or otherwise shoot them down. It is not possible to do that without compootahz.
On the other hand, shooting down a salvo from the New Jersey is going to be a bit tricky...
