Old 03-07-2009, 09:58 AM
Banned
Cobra Make, Engine: ERA 428 FE 4-speed CR "TL" heavy spline
Default Request - allow small animated avatars
Jamo/Computerworks
Would it be possible to review and change the site policy and allow animated avatars, limited to 75 by 75 pixels or 19.5 KB (whichever is smaller) or even small than that?
I tried to load one - message stated it's not allowed. Are small animated avatars a real problem?
Thanks.
Old 03-07-2009, 11:50 AM
Jamo's Avatar
Super Moderator
What format are you using?
Jamo
Old 03-07-2009, 12:10 PM
Doug I's Avatar
Cobra Make, Engine: Waiting to Order a BDR, engine to be a SA C408. TKO to hook it up.
mine seems to work ok
at least I see it animated at my end
but that might just be the meds
Pull a gear .... drop the hammer .... and enjoy the Drive !!
Old 03-07-2009, 12:14 PM
Banned
gif file, here's the message...
vBulletin Message
You may not upload animated images.
Here's the gif file...
I may or may not want to use that specific file, just wondering why no animations are allowed - I was thinking that they were allowed in the past.
Thanks.
Old 03-07-2009, 12:15 PM
Banned
It's not seeing animated, it's bring able to load an animation as noted above.
Old 03-07-2009, 12:32 PM
Doug I,
That Southern Cross is moving in the breeze here in Bermuda.
Old 03-07-2009, 12:55 PM
Doug I's Avatar
is it 5 o'clock there ?
Old 03-07-2009, 12:59 PM
Jamo's Avatar
Super Moderator
What is the total size of the similie (animation) you're trying to use? Remember, it's 75X75...but not more than 19KB.
Jamo
Old 03-07-2009, 01:49 PM
mrmustang's Avatar
Gold Star Contributor
Jamo part of the problem appears to be the size 96dpiX96dpi. File size is only 2kb . The other part of the problem might be the file name which starts with an "_" (underscore). Rename it to something different like 1american.gif and resize it accordingly and it should be good to go.
Old 03-07-2009, 02:00 PM
Jamo's Avatar
Super Moderator
OK...too many chefs in the kitchen. I'm out on this one. Good luck CDC.
Jamo
Old 03-07-2009, 03:19 PM
Banned
Oh no - help!
The file is the same as the above flag waving gif - 1.69 KB (1,737 bytes) (40 X 35)
New file, same message received...
30X45 345 bytes
Help. I'm also wondering about the 'YOU' part of the YOU MAY NOT UPLOAD ANIMATED IMAGES! Is it just me or is that a message to whoever tries it?
Old 03-07-2009, 09:11 PM
wtm442's Avatar
Beam Me Up Scottie
CDC
The computer remembers you! That's why its giving you problems. It wants to torture you.
I copied your gif picture, did absolutely NOTHING to the file, and loaded it as my avatar in the User CP area. But the CC computer likes me, so it works fine - no problems.
The score at the bottom of the first inning is
CC Computer 1
CDC 0
Warren
Old 03-08-2009, 09:16 AM
Banned
Originally Posted by wtm442 View Post
CDC
CC Computer 1
CDC 0
Your established wierd sense of humor, right? But, not true, correct?
Old 03-08-2009, 09:32 AM
wtm442's Avatar
Beam Me Up Scottie
Not wierd.
It worked for me.
No problems adding your gif picture as my avatar.
The problem therefore is NOT the gif file.
Look at my avatar - its your gif picture.
Suggest you try again.
Good Luck and pray to the computer Gods.
Warren
Old 03-08-2009, 11:26 AM
Banned
I apologize for the wierd comment.
So, Ron tried it also - worked for him - therefore, it's all about me - normally I like it that way, but not in this case - perhaps Jamo will be kind enough to help me out - it must be something about my account.
Thanks.
