| S |
1 |
| 5 |
8 |
| 12 |
15 |
| 19 |
22 |
| 26 |
29 |
30 |
06-05-2009, 10:48 AM
Any appliance repair guys here? Bosch dishwasher problem..
Guys,
I have a Bosch SHU5302UC dishwasher. It has what should be a VERY easy problem to repair. The drain hose leading to the sink that discharges waste water is split and needs to be replaced. I have done this many times before on other dishwashers and it is usually a 5 minute job. The problem is with this dishwasher it has a casing that surrounds the entire unit, even the bottom, and the hose disappears into the casing. I have to get to the hose connection to the unit that lies inside the casing. How do I do this? I have never seen a dishwasher built like this before. Anyone have any ideas?
I can't begin to figure out how to remove this case, and I don't want to blindly start removing screws because none of them look like they obviously hold the casing on, and I am afraid of what might fall off inside the unit that I will then need to repair as well. If anyone has any information on how I replace this hose, or suggestions on a website or book where I can obtain more info I would appreciate it.
Sorry for the "off-topic" post, but I continue to be impressed by the vast array of differing talents assembled on this site. Thanks in advance.
Doug
06-05-2009, 11:54 AM
Doug,
How about try here:
( http://www.partstore.com/ModelSearch...mber=SHU5302UC )
Finish selecting your exact series of model [choices, SHU5302 UC/06 (FD 7705-7912), SHU5302 UC/11 (FD 8001-8003), or SHU5302 UC/12 (FD 8003-)].
The drain hoses look like they fit many applications and sell for $12.95 . There seems to be many pages of parts available (I didn't look at all) so look for a repair manual to order at the same time, which is what you needed in the first place.
One way if all else fails.
Wes
06-05-2009, 02:25 PM
Thanks, Wes - no luck on the repair manual.
06-05-2009, 03:44 PM
AL
http://www.applianceblog.com/
Pay the $5 to join. It is lifetime. I have used them to fix my dishwasher, and my icemaker. Love that site! I also used it to trouble shoot a Insinkerator.
The folks here are very helpful. Search on your model number for repairs already done.
Mike
06-05-2009, 03:58 PM
FL
Cobra Make, Engine: Kirkham #570 w Shelby FE
Think the Maytags are like that too. You have to slide the dishwasher out of the case. There is a couple screws in the front behind the plate under the door.
It's probably not even made by Bosch, just a re-branded Whirlpool or Tappen like Kenmore (Sears) does.
Instead of a repair manual look for an installation guide.
I couldn't find that model listed on their side but this may be similar:
http://www.bshextranet.com/files/tec...ram_2_in_1.pdf
You'll have to remove the right filler panel from your counter to get at it (hopefully without pulling up the countertop). I see what your talking about now, you can't pull it out of the case like most ones I've seen.
06-05-2009, 05:44 PM
Fl
Cobra Make, Engine: Antique&Collectible 392 stroked
Just splice the hose and be done with it
pops67
06-05-2009, 05:46 PM
I wish I could - it's one of those ringed white plastic hoses, I can't get a clean splice on it.
06-05-2009, 08:23 PM
Ca
Here you go, Images are on the left after clicking on complete model number.
http://www.appliancepartspros.com/pa...odel=SHU5302UC
Rick
