Go Back   Club Cobra > Club Forums > New England Cobra Enthusiasts
Like Tree3Likes
  • 1 Post By mickmate
  • 1 Post By trularin
  • 1 Post By mikiec
Old 03-23-2015, 05:07 PM
Cobra Make, Engine: 1966 ac cobra body CMC 351 Cleveland 409 H.P.
Question Help!!!!!!!!
I have a 1966 ac cobra that was built by Classic Motor Carriages out of Florida. They are now out of business. I am trying to find or how to find the original manual or build sheet on how to put this vehicle together. Having issues as to the rear suspension and to what could have been used on my car. These are my problems and if I could find the build manual would help me out. Chassis rear differential is not installed correctly. Left and right upper and lower rear differential trailing arm bushings are twisted in arms. Rear differential pinion angle is pointed down ten to eleven degrees which is causing drive shaft rear u-joint to grind into rear differential output flange and pull driveshaft slip yoke out of transmission. Rear shocks are not right. Rear coils springs are not installed correctly or are wrong for the vehicle and are hitting the frame. Left and right rear shock mounts are wrong. There are no bushings in the shocks. These are just a few of the main issues. Trying to figure out what they reccomened for this vehicle. Any help at all would be greatly appreciated. Feel free to call me if you need to. My cell is 508-864-4083. Thank you all in advance. Raoul Chalifoux Tolland Ct.
Old 03-24-2015, 04:41 AM
mickmate's Avatar
Here's a start. 79 04 Mustang Radius Rod Uppers Spherical Bushing Kit | eBay
Pull some shocks and do some measuring then check over here http://www.energysuspensionparts.com...e-Bushings.asp
raoulmc likes this.
mickmate
http://www.actoncustom.com/
Old 03-24-2015, 06:39 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
First settle down. There are a rather large number of members in the group and the knowledge base is formitable
First, please take a few ( or as many as necessary ) pictures of your setup.
Post them and let everyone give it a look.
Ask point questions so they can be addressed. Open ended ones will draw a discussion with a lot of opinion.
All is not lost, it will just take some time.
I hope this helps.
raoulmc likes this.
Old 03-25-2015, 07:13 AM
mikiec's Avatar
I am not completely positive but when CMC went out of business, you can research why, they reemerged as Street Beasts. Hopefully some one will verify this.
Mike
raoulmc likes this.
