Go Back   Club Cobra > Club Forums > NorCal Cobras
Old 06-10-2009, 01:26 AM
culdad's Avatar
Cobra Make, Engine: Superformance Roush 327 R
Default tech question
when the engine is running the tach, fuel gauge, blinkers dont work...when i am not running the engine everything works except for the tach obviously...alternator or battery is bad...also when there is a full battery attached to the on board battery everything works...help please
the more you know the more you know you dont know
Old 06-10-2009, 05:37 AM
Default voltage
A low voltage problem most likely.
First thing to check is engine to frame ground.
Battery connections
Wiring to alternator next
Then check voltage while running. Should be 13.6 volts at the battery minimum
Old 06-10-2009, 08:01 AM
jrjmac1's Avatar
You could hire a Porsche to follow you and help with a jumpstart as needed!
"Live Life Abundantly"
Old 06-10-2009, 08:36 AM
Ron61's Avatar
Post
What 747 said plus you might have the battery load tested. A bad cell can cause the alternator to not be able to charge it and keep the voltage up, but normally it would also be low when the car is stopped.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
Old 06-10-2009, 09:57 AM
culdad's Avatar
were you at crush 29 last night?
Old 06-10-2009, 10:49 AM
wanab5150's Avatar
Cobra Make, Engine: Superformance #2769 Roush 427R Dart Block
Don't listen to Jrmac1 (John).... Just ask him how a GTO runs on 7 cyl. That'll shut him up!!! See me for details!!!
A lot of modern electronics require more than 10 volts just to function. Anything less and they act ADHD.
Step 1...Swap the battery out of you wife's car and put it in the Cobra.
Step 2...If that cures the problem, go to Step 3.
Step 3...When she tells you the "Family Truckster" won't start you say "It needs a new battery".
Step 4...Buy a cool new Gel Battery and swap it back into the Cobra during the early hours of the morning while she's asleep.
Step 5...If that fails, refer to 727's instructions!
PS.... This works for an array of other situations. Tom
Tom
I miss my Tazer
Old 06-10-2009, 11:31 AM
With the engine running at idle, turn on the headlights.
Are they on? Does the engine die? Are they bright or dull? Now rev the engine. Do they get brighter when revved? Battery or ground.
Old 06-10-2009, 11:43 PM
jrjmac1's Avatar
Don't listen to Tom either...just ask him how a Chevy Tahoe runs with mud up to the floorboards!!!
Old 06-11-2009, 11:38 AM
wanab5150's Avatar
It ran on all 8 though!
Tom
I miss my Tazer
Old 06-11-2009, 12:53 PM
culdad's Avatar
you guys are hilarious...mostly not helpful but hilarious...changed the alternator and voltage regulator and voi la...thats french for the damn thing is fixed...
Old 06-11-2009, 06:30 PM
jrjmac1's Avatar
Hey culdad, yes I was there next to the Chevelle. Glad you solved the electrical issues.
Hey Tom, the only 8 you were running on was the 8 in the truck that pulled you out!
Old 06-11-2009, 11:13 PM
wanab5150's Avatar
Bite Me. Remember....the 8th plug wire is not just a spare!!!
Tom
I miss my Tazer
Old 06-11-2009, 11:27 PM
jrjmac1's Avatar
Tom...it's past your bedtime.
Old 06-12-2009, 10:27 AM
wanab5150's Avatar
Fine.......
Tom
I miss my Tazer
Old 06-12-2009, 02:03 PM
thudmaster's Avatar
Regularly Offensive
Cobra Make, Engine: spf
Did you check your tire pressure?.........................
Ed
Too close for missles, switching to guns.........
