Go Back   Club Cobra > Club Forums > NW Cobra Club
Old 09-22-2006, 05:26 PM
Ron Going's Avatar
Cobra Make, Engine: ERA FIA 2095, 331, w/ TKO 500
Default Cold Air Box Install
Can someone tell me what the best gasket setup is when installing a "turkey pan". I'm sure you need a gasket on the intake manifold and then one between the carb and the cold air box. Just curious what others may have used to prevent vacuum leaks. Lastly, is there one cold air box that is better than the rest? Thanks for the help. Ron
Old 10-05-2006, 06:29 PM
Ron Going's Avatar
Come on guys.....someone must have done this before. How about some words of wisdom. Thanks
Old 10-05-2006, 08:06 PM
Sorry Ron, I was waiting for someone to answer your post also because I have the same questions.
Old 10-06-2006, 12:40 AM
I just used a couple of the standard carb base gaskets, that you should be able to buy at the local autoparts store, and sandwiched the turkey pan between the carb and intake , and also possibly a spacer.
I bought mine from Kirkham. However, It wouldn't fit on my friends 351W with the distributor. He got his from somewhere else, with a shortened front to clear the distributor
Old 10-11-2006, 09:34 PM
Cobra Make, Engine: Classic ND 427 big block 427 ford with tri power I know the 427 didnt come with tri power just wanted something different. 9 inc. ford rear end top loader four wheel dic brakes.
Ron,
I have a 427 in my Cobra and used the same set up as Anthony posting. I due have a one inch. spacer with stock casket on each side. I had to cut some holes in my turkey pan bottom so the carb linkeage would move with out hitting the pan bottom. I also had heat treating done to the pan. The same stuff they put on header pipes. I got the pan at Finish line Inc wwwfinishlineaccessories.com There was no problems with distributor clearing. I have had no vac. leaks. I have a friend who has a new one that he didnt use, he may want to part with it? Its for a 351 ford. Let me know.
Andy
Old 10-13-2006, 10:02 PM
G.R.'s Avatar
Send a message via Yahoo to G.R.
Andy did you get your car sorted out?
Sorry for the hi-jack
