Go Back   Club Cobra > Club Forums > Ohio Cobra Club
Old 02-11-2004, 11:23 AM
Cobra Make, Engine: MIDSTATES, 408C
Default "Cleveland" Ohio machine shop
Can any of you Ohio builder/owners recommend a Southern
Ohio machine shop that has 351/400 Cleveland machining
experience. I am relatively new to the state and need a
set of quenched 4v heads worked, specifically I need the
pedestal slots machined off to accept studs and guideplates.
I don't want just anyone to try to do it. I am presently running
the Crane conversion kit but don't like it and am going to a
fairly radical cam. Thanks in advance.
Bob Taylor
Old 02-11-2004, 12:17 PM
rdorman's Avatar
Renegade Nuns on Wheels
That is a fairly simple procedure but I understand your misgivings. The only one I know down there with a good rep is Performance Engineering in Ross Ohio. Do a search around here and you will find all kinds of information on them.
Last time I was there they had some SWEET aluminum Cleveland heads there!
OhioCobraClub.com
LondonCobraShow.com
Old 02-11-2004, 12:33 PM
dalola's Avatar
Cobra Make, Engine: Project "X" underway....twin turbo V6, AWD...
Bob,
If you don't mind a short drive north, one of the finest engine shops anywhere is right here in Columbus, Fowler Engines. If nothing else pans out, you might give them a look.
Here's a link: http://fowlerengines.com
Good luck!
~Dave
Old 02-11-2004, 01:42 PM
Thanks Rick and Dave. I have a spot facer but am chicken to
attempt it with just an electric drill. These 4v heads are
getting fairly rare to just play around with. I will check in Ross
and will stop in at Columbus. I work at the Bud brewery on
weekends so it is not out of my way. I look forward to meeting
you both at one of the Ohio club functions. Thanks for the
info.
Bob T.
Old 02-11-2004, 02:24 PM
Double Venom's Avatar
Dave beat me to it.
Fowler IS the Ford shop to go to. Right 0ut side of Columbus.
DV...
Old 02-11-2004, 03:24 PM
Thanks DV for your recommendation. I look forward to meeting
you as well. I wish I had this fine community of people 40 years
ago when I started streetrodding. This makes is alot easier!
Bob T.
Old 02-13-2004, 11:45 AM
rdorman's Avatar
If you are up this way (Columbus) then Fowler is an impeckable shop. They can do anything!
OhioCobraClub.com
LondonCobraShow.com
