Old 03-11-2010, 06:35 PM
Default Original Prop Rod
I am looking for a close to original as possible hood prop rod for my BDR Cobra. Does anybody have any suggestions?
Thanks,
Michael
Old 03-11-2010, 06:54 PM
mickmate's Avatar
A piece of 3/8 OD tube squished flat at one end and through bolted to a tab on the frame with a bend about 3 inches away to clear the body. A rubber cap over the other end, small clip to hang that end in, done deal.
mickmate
http://www.actoncustom.com/
Old 03-11-2010, 09:06 PM
289ACE's Avatar
Cobra Make, Engine: 2 AC Aces, 1 w/289, 1 w/TBD
I made mine just like mickmate describes. Put the end of the tube in a vise and flattened it, drilled a hole thru it, took a tubing bender and made the bend until it looked right and then put a vacuum plug cap on the end. Looks like it came with the car originally.
Jay
Old 03-12-2010, 08:29 AM
428street's Avatar
Cobra Make, Engine: BRG ERA street car w/428 PI, Sunburst wheels, undercar exhaust, original interior, no philips head screws!
Check with Mickmate first, maybe he can make you one...if not, I know Cobra Restorers has them (at least they did 3-6 months ago).
Old 04-01-2010, 08:16 PM
mickmate's Avatar
I have them if you need one.
mickmate
Old 04-02-2010, 06:42 AM
dlampe's Avatar
The picture on cobra restorers isn't that good. I went to Mick's site and didn't see a picture there either. I guess I am confused about the flattening of the tube and the 90 deg bend. Does someone have a picture of this??
High Maintenance Racing Team
Run & Gun 2003 - 2013
Old 04-02-2010, 08:18 PM
mickmate's Avatar
It's more like a 40 deg bend. The CR pics just show the ends, a cap on the hood end a bend and flat on the hinge end. Pics are coming, yeah I know and so's Christmas right.
mickmate
Old 04-02-2010, 09:30 PM
LMH's Avatar
LMH LMH is offline
Here's one of a Kirkham.
Alba gu bràth
Old 04-03-2010, 07:27 AM
dlampe's Avatar
Now I understand!
Old 04-03-2010, 08:01 AM
can you tell me how it fixes to the footwell/body?
thanks
kevin
Crendon 427, in the making
http://crendonreplicas.com/
Old 04-03-2010, 08:18 AM
289ACE's Avatar
There is a small clip that the rod slips into to. I'll try and get a picture a little later.
Jay
Old 04-03-2010, 06:33 PM
mickmate's Avatar
It has a 1/4" screw that holds it to the tab coming off the birdcage. The tabs are the same as the hood and trunk hinge brackets.
mickmate
Old 04-03-2010, 08:39 PM
289ACE's Avatar
I posted pics of my prop rod setup in my gallery and here they are also.
Old 04-13-2010, 06:59 AM
many thanks for the pics
Old 04-13-2010, 08:00 AM
1985 CCX's Avatar
Nick will be making mine provided I get that far..............Top notch parts at reasonable prices...
Old 04-14-2010, 08:40 AM
Cobra Make, Engine: JCF supplied the body,frame,and some of the driveline-I completed it to be a very accurate 289 slabside
That clip that holds the rod is not what the 289's had (not sure about 427's). It should be a vertical mount "J" shape. I might find a picture.
Old 04-14-2010, 04:32 PM
mickmate's Avatar
Hey Jeff that is yours get back to working on it. The 289's have the rod hinged off the hood latch according to the ones noted. It also has a second bend with one half way along to keep the hood end parallel with the inner fender.
mickmate
Old 04-14-2010, 09:10 PM
289ACE's Avatar
Once again I learned some things. I wasn't positive the clip was the same as used on the 289s, but the second bend in the rod is something I have never heard before. It sounds like a good idea and I may have to remake mine to add that.
Jay
