February 2026
Old 07-21-2010, 07:44 PM
Question shaved the front turn signal bosses on FFR....Did I oops?
I installed the liights and Turn signals tonight and think I might have oopsed!
Background info: I am trying to replicate a 66 SC as best I can
1st, I drilled the 2 holes in the body for the mounting screws on the back of the Turn signals where I did so that I could control (shim) the down and out angle the TS has in refrence to the headlight. Only problem is that I did not see that I cannot adjust the lense cover (rotate it) to make the 4 fins in the lense itself go in a North/South - East/West direction until AFTER I put the lenses in. I am pretty much stuck with the diagional look unless I pull and redrill, which I could do.
SO MY 1st QUESTION IS:
What was the origional orientation for the early 65/66 cars? The origional I have to reference here locally is a '67 street and it has the later/different lenses.
2nd, The turn signals I received with my kit are a pretty cheap press on covers ( I also have a set of clear lenses) and as you can see it leaves a real UGLY unfinshed gap.
MY 2nd QUESTION IS:
What can I do about this? Should I just order different aftermarker lights?
What are your thoughts guys?
Thanks
Old 07-21-2010, 08:08 PM
If you go here:
http://shelbycsxinfo.com/3000-Series/
you'll see that several cars have diagonal orientations of the lenses and that same gasket gap you are referring to. However, given that you are bent on being original, the vertical face of the mounting area is not 90* to the ground as is suggested by your side view. The area where the lamps mount is slanted to the rear at the bottom, like this:
The incorrect body details like this are far more noticeable than the lamp orientation.
Old 07-21-2010, 08:19 PM
ELM
Thanks for that picture! It helps a TON in regard to the slant. However, I don't think I have enough glass in the FFR body to put that drastic of a slant into the body....
UGH, I tought I was pretty close.
Good to hear about the diagional lense and gap orientation. That saves me a little work.
Do you have any pictures or specifil links I can see better what the gaps look like?
Old 07-21-2010, 10:43 PM
LMH's Avatar
LMH LMH is offline
The turn signal also points out as compared to the headlight. From your photo's, I don't think you did too bad a job!
http://www.csxinfo.net/web/modules/x...301&fullsize=1
Alba gu brąth
Old 07-21-2010, 11:12 PM
Lots of reference pics here:
And here:
http://www.csxinfo.net/web/modules/x...ndex.php?cat=5
Old 07-22-2010, 04:53 AM
mickmate's Avatar
Hey Dan that looks great carry on.
mickmate
http://www.actoncustom.com/
Old 07-22-2010, 10:14 AM
rodneym's Avatar
Full Blown Member
Premier Contributor
It seemed strange to me at first but the TS definately point down and outward on CSX and accurate replicas.
Kind of like Marty Feldman's eyes or what my friend calls "grandma's titties".
Old 07-25-2010, 07:45 PM
Thanks Larry
Old 07-25-2010, 08:23 PM
1985 CCX's Avatar
Dan
Atta boy!
Old 07-25-2010, 09:25 PM
LMH's Avatar
LMH LMH is offline
Dan, tell me more about your headlights. Are those repro's with modern bulbs or just exactly what are those?
Alba gu brąth
Old 07-26-2010, 10:44 AM
They are repos of the old lucas tri-pole (tri-bar) and they have halogen inserts. I got them from cobrarestorers I think. $150 for the pair with bulbs. You use your existing (in my case FFR) hardware and buckets.
