01-06-2013, 05:40 AM
n/a
Leaf spring 289 wiper motor mount
Can anyone tell me how the wiper motor (DR3) was mounted to the top of the LH footbox? I know XK Jags which used a similar motor had a metal plate fixed to the body to which the motor was mounted using the usual three hex-shaft bolts with rubber insulators.
For the Cobra, was the footbox simply drilled big enough to take the same rubber insulators? It seems too thick for this, but I guess there's every chance the motor was simply bolted to the top of the footbox without any rubber insulators.
01-06-2013, 07:26 AM
Three holes. Rubber washers captured by steel washers both sides of fiberglass.
Dan Case
01-06-2013, 07:38 AM
n/a
Thanks Dan. As with the vinyl/carpet thread, I don't know what we'd do without input from guys like you.*
Roger
*Well, yes I do know - we'd get it wrong!
01-06-2013, 07:43 AM
Your welcome.
I don't remember if rubber isolators are a molded grommet or just a flat washer as I haven't had one of those parts loose in my hands since made 1991.
Dan Case
01-06-2013, 08:32 AM
Molded on mine when i bought motor. I switched to new flat typ0e as easier to get it together.
01-09-2013, 12:49 PM
n/a
I'd be really grateful if someone with a 2000 series car could stick their head in the footwell and give me a rough idea of the diameter of the rubber/washer on the underside mount.
01-09-2013, 01:25 PM
Cobra Make, Engine: CSX2498 has been in our family garage since '68....Scratch built aluminum bodied 427SC Cobra, 427FE, CSX3000 chassis specs, 95% finished, only needs paint.
washer sizes
Hello, the steel washer measures just under 1" and the rubber washer is approx. 1/8" thick and bulges out slightly to approx. 1".
meas. from CSX2498
later, karl
01-09-2013, 02:03 PM
Mine match's Karl's
01-09-2013, 03:47 PM
n/a
Brilliant, thanks guys. That sounds like the standard-issue Lucas wiper mounting kit.
