Old 11-04-2013, 07:33 PM
Cobra Make, Engine: FFR MKII Levy 347
Default Fans
The origional 427SC ofcourse hastwo pusher fans. Did it also have "puller fans" behd?
Bill
Old 11-11-2013, 08:33 AM
DougD's Avatar
No, they did not.
Old 11-11-2013, 08:42 AM
mickmate's Avatar
Many aftermarket ones were added by quite a few as the need arose. You'll see some clever variations utilizing the top and bottom radiator mounts for the addition of pullers.
mickmate
http://www.actoncustom.com/
Old 11-11-2013, 05:15 PM
I mounted mine using some L-shaped brackets off the opt mounting, udnerneath the folded ali top plate.For the bottom of the fan I made some folded sheet brackets that mounted underneath the steering rack.
Crendon 427, in the making
http://crendonreplicas.com/
Old 11-12-2013, 08:21 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
After a few tries with various configurations and a rack that seemed to get in the way ALL the forking time, a 3/4 inch fan shroud using 3/4 inch angle aluminum with SS screws worked.
Then I took it off and put the old fan back on.
The other thing I discovered was the thermal turn on - turn off circuits available at several places are somewhat temper-mental ( like that? ).
If you put in a puller, I recommend fan shroud and 12 battery ( direct connect ) temperature control.
Just my $0.02 worth.
Tru
