Like Tree1Likes
  • 1 Post By rsk289
Old 05-15-2014, 12:21 PM
rsk289's Avatar
Default Spare wheel fittings
I now have one of Jim Feldman's excellent spare wheel wingnuts in cast aluminium. It has a ⅜ BSW thread. Can anyone with access to an original car tell me what the other parts of this fitting should be? From guesswork I would assume some threaded rod, fixed to the spare wheel well base by a nut either side of the fibreglass with suitable washers to spead the load. Right idea, or too simple? This is a leafspring, rack-and-pinion 289, but I imagine they're all pretty similar. I know the Ace used this same cast nut.
Roger
Old 05-15-2014, 03:39 PM
Dan Case's Avatar
Original Shelby Owner
Dan Case
Old 05-15-2014, 04:36 PM
1985 CCX's Avatar
Very cool
Old 05-15-2014, 05:57 PM
LMH's Avatar
LMH LMH is offline
That's an awesome photo Dan, thanks!
Alba gu brąth
Old 05-15-2014, 06:43 PM
Senile Club Cobra Member
Dayum, Dan....whatever the question you have the answer.....with pictures!
Thank you for your participation.
rick@autoventureusa.net
Old 05-15-2014, 08:15 PM
mickmate's Avatar
I have all those pieces Roger, just not on the site yet.
mickmate
http://www.actoncustom.com/
Old 05-15-2014, 11:59 PM
rsk289's Avatar
Wow, Dan - is there anything you don't have a photo for? And are so generous in posting to help us?
Thanks, that's pretty much what I guessed should be there and it's really helpful to know for sure. Another piece ticked off the list.
Roger
CompClassics likes this.
Old 05-16-2014, 04:15 AM
Dan Case's Avatar
Your welcome. There are thousands of pictures I don't have but the current inventory is over 13,000 and that was after I culled about 8,000 out earlier this year.
Dan Case
Old 05-16-2014, 04:55 AM
Dan Case's Avatar
f.y.i.
If the car is driven in a sporting manner with spare in place and or on rough roads the spare tire assembly will move around a lot. Over the decades owners of more than a few original cars have turned down the nuts so tightly that they bend the top discs and or break the fiberglass trays. The assembly will still move a lot. About 1985 I had a piece of 6061 T6 aluminum round bar stock turned to make sturdy tapered on one end helper for the top disc. With this tapered device holding against the wire wheel hub taper the spare tire nut doesn't have to be very tight to hold the wheel very much more securely.
I think I sent that drawing to mickmate also?????
Here's a picture of the one made circa 1985. I still have the original top disc in place and you see where it had gained a cupped shape by the time I got the car.
Dan Case
Old 05-16-2014, 07:37 PM
mickmate's Avatar
Spare Wheel Hold Down Hardware [289] - $32.00 : Acton Custom Enterprises, Custom Metal for Cobras
mickmate
Old 08-27-2014, 05:09 PM
mickmate's Avatar
Nuts now too.
Spare Wheel Nut 289 Spare Wheel Nut 289 [289 street cars] - $65.00 : Acton Custom Enterprises, Custom Metal for Cobras
mickmate
Old 08-27-2014, 05:27 PM
1985 CCX's Avatar
Set one aside for me.
Old 08-27-2014, 05:32 PM
LMH's Avatar
LMH LMH is offline
Nice job Nick!
Looks like I need to order the hardware! Already have the nut.
Alba gu brąth
Old 08-28-2014, 03:35 AM
mickmate's Avatar
Got you guys covered.
mickmate
