Old 03-16-2015, 10:05 PM
Bill D's Avatar
Default What AWG Wire?
What AWG wire was used on the firewall components of original cars? I'm trying to replicate the look and would like to be somewhat accurate in my attempt.
Bill D
Old 03-17-2015, 03:47 AM
Tommy's Avatar
Bill,
While you are waiting for the answer, I have a question for you. Are you also replicating the electrical loads from the originals (e.g., same output alternator, same amperage ignition, etc.)? It would seem that replicating the look could be a problem if the electrical demands are larger.
Tommy
Previously owned EM Cobra
Old 03-17-2015, 06:06 AM
Bill D's Avatar
Tommy, the firewall components will not be functional but for original look only
Old 03-17-2015, 11:55 AM
Tommy's Avatar
Very interesting. Thanks for sharing.
Tommy
Old 03-17-2015, 08:14 PM
LMH's Avatar
LMH LMH is offline
I haven't taken an original harness apart, so I'm pretty much guessing but I'd say it's either #14 or #16 for the most part. Keep in mind that there is different size wires depending on what/where they go and what fuse they come from. The other thing to keep in mind is on the engine side, most of the harness is wrapped and not exposed to the elements. It separates at the firewall plugs and whatever device it's attached to. Even behind the firewall, a lot of it is wrapped. Also, on original cars (post 2201 standard leaf spring cars), some of the harness is Ford Autolite and some of the harness is Lucas. There are short connectors with a Ford plug on one end and a Lucas plug on the other separated by a couple inches of wire to connect the two together.
So it kind of depends on how closely you want to replicate it as to what you want to use.
Here's a pic of the firewall, less engine with the harness in place:
Alba gu brąth
Old 03-17-2015, 08:41 PM
Bill D's Avatar
Thanks Larry
