17Likes
02-15-2016, 12:25 AM
CH
Identifying dash warning lights 289
Im trying to identify the dash warning lights used un a 289 dash (in this case the same as used on CSX 2514)
Green: Flasher warning lights should be Lucas WL12.
Red: Ignition warning light ? (some information I found mention Lucas WL3, but this is not a WL3) ->?
Blue: Main beam warning light (small lamp on top) -> ?
If you know a source for them it would be highly appreciated.
Driving with your Cobra is fun,
Racing with your Cobra is amazing,
Driving hill-climbing races with your Cobra is.... HAVEN!!
02-15-2016, 02:03 AM
CSX2201 and later
Turn Indicators
Turn Signal Flasher Warning Light Assembly (2)
54360730, Lucas Model WL13, Color: Green
Except sockets replaced by a Ford/Essex bulb holder
incorporated into the large Ford/Essex wiring loom behind
the dash .
Ignition Warning Light, Red
Ford / Hobbs / Essex, Cobra unique with text free bezel,
Ford engineering information, in this case a standard Ford
Design changed for use on Cobras, on the wire loom pigtail reads:
SX
FoMoCoŽ (FoMoCo oval logo)
C3TB-10A934-A (engineering number, which is the truck part
it was based on and not the Cobra part)
Headlight Indicator Light Socket
O1C 13583 Ford / Essex, 1940 Ford
Headlight Indicator Light Jewel Assembly, Red
O1C 13586 Ford / Essex, used in various Fords between 1940
and 1952 model years, that includes some Ford built military
vehicles.
Dan Case
02-15-2016, 05:07 AM
Dan
"A" for the day! Always great to get your detailed information.
I know I appreciate it tremendously.
Thank you
Jeff
02-15-2016, 06:52 AM
High beam indicator is replicated. Two styles are made, long and short. You need the long one. Lucas style indicators are also replicated. Acton may have them.
The tough one is the ignition lamp. It hasn't been replicated as far as I know but the fixture can be bought on eBay pretty easily. Ford Truck emergency flasher lamp. You can have a new bezel made.
Alba gu brāth
02-15-2016, 03:03 PM
n/a
Just for completeness, the picture is a little easier for COB/COX cars: Lucas ignition warning light - as used on earlier Triumph TR, or MGA. Small green indicator repeaters are made by SVC, and the high beam indicator is a red jewel light set into the face of the tachometer, just visible in the photo. This is COB6029, John Haynes' car (he of the manuals).
Roger
02-15-2016, 04:29 PM
Roger, what's the cable pull over the glovebox?
Alba gu brāth
02-15-2016, 04:44 PM
Cobra Make, Engine: SPF 289 Street
Larry,
Pretty sure that's a map light.
02-15-2016, 04:46 PM
I have to chuckle when I see ash trays in these cars. The world was your ash tray back then
02-15-2016, 10:44 PM
CH
This is the reason why I like this forum.
You get an amazing amount of detailed information back from many different members.
Many thanks for that!
@rsk289: The ignition warning light on your picture is a Lucas WL3 and you can get them replicated from SVC as well. (search for COIL WOUND DASH WARNING LIGHTS RED)
@ Dan: you should write a book with all the information/pictures you can provide.
02-16-2016, 12:39 AM
n/a
Originally Posted by Armrer
Larry,
Correct, it's a map reading light. One source has suggested this was a factory fitment for UK cars, but I'm not convinced. Trouble is, there aren't many UK cars available to check, and most have been heavily 'restored'. COB6029 has been molested very little, however. But this kind of aftermarket light was very common in the late sixties - I had one in my Morris Minor Traveller.
Roger
02-16-2016, 06:11 AM
FYI, the high beam jewel is replicated but the lamp socket Dan posted appears to be Cobra specific and isn't replicated. You can use the lamp socket from the 40 Ford to make it work though.
Alba gu brāth
02-16-2016, 08:06 AM
CH
Hi Larry
Many thanks for the picture. I found allready some sources for it.
Do you've any information about the ignition warning light? I was not able to find a seller for it until now.
02-16-2016, 09:45 AM
Ford Truck Emergency Flasher Lamp but with a plain bezel. Came on trucks in the early-mid 60's. Cobra specific though as an assembly, not used on other vehicles. The truck flasher lamp is common on eBay. Have someone matching out a bezel to replace the factory bezel and have it chromed.
Alba gu brāth
02-16-2016, 11:58 AM
Note the flasher lamp on the right. They come up for sale fairly often as just the lamp assembly w/o the switches and other hardware. You'd need to have a new bezel made to replace the "Emergency" bezel.
64 65 66 Ford Truck Dash Switches Ignition w Key Lights Wiper Emergency Flasher | eBay
Alba gu brāth
02-16-2016, 04:27 PM
I made my ignition light using an off-the-shelf red 3/4" indicator light and a switch bezel off a big early 60s Ford. I milled a 3/4" hole in the bezel and inserted the light. The headlight indicator is just a red LED press-fit into a stainless finishing washer. Not concours, but I think a fair representation.
02-28-2016, 08:47 AM
CH
I've the ignition warning light (as used on Ford Bronco's) on my desk.
Now the challenge starts to get the "Emergency" bezel replaced with a blanc one.
04-20-2016, 04:39 AM
CH
Still had no luck finding someone reproducing the blanc bezel for me.
Have the Ford version in my hands, but this is with the "Emergency" text on it.
04-20-2016, 07:27 AM
As far as I know, it was produced as an assembly for Cobra only. Chances of finding an original from a Cobra are somewhere between slim and none. I think Jeff was THE lucky one! We are looking at making some bezels but so far, it's been way too expensive. (read thousands of $$)
Someone who does machining might be able to make one, so that might be something to look into.
Alba gu brāth
04-20-2016, 09:50 AM
Repop, there will be takers cool:
04-20-2016, 10:51 PM
CH
Yes and I'm still hoping Nick or John can help.
The warning light is mainly done out of 4 parts. - bulb holder
- retainer
- front cover
- red lens
The point is now finding some one able to reproduce a blank front cover.
